Mirroed Collection Intances have flipped normals/face orientation.
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.39
Broken: version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-07 19:17, hash: 3dc9da3a74ee
Worked: version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-03 21:09, hash: ee0d8426ab6d
Mirroed collections instances have flipped normals in 3D viewport.
Screenshot of viewport with face orientation turned on.
Blue cube is the original mesh in a collection. Red cube is the collection instance mirroed in the X axis.
  1. Create collection with any mesh.
  2. Add a Collection Instance of that collection
  3. Use mirror operator with any axis.
Jeroen Bakker (jbakker) claimed this task.
According to @Clément Foucault (fclem) correct fix is to use apply the flag OB_NEG_SCALE on dupli if the parent has the flag. and remove it if both are true would be nice to have that done in the depsgraph tho
@Sebastian Parborg (zeddb) yes, I also want a good opinion about it. currently OB_NEG_SCALE (and its draw manager counterpart DRW_CALL_NEGSCALE) only influences the BACK face checking, what is too limmitted. I can see @Clément Foucault (fclem) analysis to be correct. But before we put any change in depsgraph I want to have some guidance on where and how.
My guess would be deg_objects_dupli_iterator_next
We noticed that normals are off due to recent changes. Here I will elaborate what my findings are. More issues I have seen might be related to this.
Scene I used for testing
4 days ago rB21f8e75ddb6b: fix image_changed() doing unneccessary texture updates when texture wasnt using… everything seems correct
Current master rB6b082278d195: UI: expose tool settings in the 3D view side-bar shows normals inverted and mirrored
Somewhere in between I see flipped normals (but not mirrored)
The inverted normals are introduced by rBddb71e8c20c2: DRW: Remove is_negative_m4 per draw call
The mirrored normals are introduced by rB733811330c9b: Workbench: Use common_view_lib and remove NormalMatrix usage
It might be that the mirrored normals was a fix so we need to check this against EEVEE normals in this case.
Broken eevee normals are introduced by rBf2f62b184c67: DRW: Remove WorldNormalMatrix
Emir Sinan Gürlek (filibis) reopened this task as Open.
I think this issue hasn't been fixed properly or popped again. I'm getting artifacts when I select a mirror object to use as mirror.
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-06-19 18:29, hash: rBd30f72dfd8ac
Jeroen Bakker (jbakker) closed this task as Resolved.Jun 27 2019, 10:52 AM
Hello, @Emir Sinan Gürlek (filibis)
Sorry for this, but could you please open a new report, it is not related to this issue. Your issue is related to autosmooth. When you disable autosmoothing it renders fine.
I will change this issue to resolve as this is related to collections mirroring, what is working as expected.
Sorry @Jeroen Bakker (jbakker) , I thought the issue is related. I created a new report for this: T66183
