Mix Shader Result is Turn Solid Magenta in Eevee
Operating system: Windows 7 SP1 64-bit
Graphics card: Geforce GTX 670
Broken: Blender 2.80 2019-05-07 00:16
I cannot share .blend file on public area. When mix two group node in Eevee, then result turn solid magenta color:
Node Group 1:
Node Group 2:
Mixed Result:
Sebastian Parborg (zeddb) closed this task as Archived.
Sebastian Parborg (zeddb) claimed this task.
If you can't share a setup that has this problem, there is not much we can do.
