ERROR: Attempt to unbind (Surface Deform) from inactive dependency graph, when using *Redo Last*
Operating system: Linux-4.13.10-041310-generic-x86_64-with-debian-stretch-sid 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.67
Broken: version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-07 19:17, hash: rB3dc9da3a74ee
Worked: 2.79
In an operator I add a Surface Deform mod to an object, bind it to a 2nd object and then deform that 2nd object (using Shrinkwrap).
This works, but only for the initial run of the operator, not for redoing.
  • open
  • run the script and run the Deformer op n the 3d view
  • as intended the box is surface deformed by the plane which is shrinkwrapped
  • as soon as you use *Redo Last*, the terminal shows the following error, and Blender will apparently fail to re-bind the Surface Deform
ERROR (bke.modifier): /home/sources/buildbot-x86_64-slave/linux_glibc224_x86_64_cmake/blender.git/source/blender/blenkernel/intern/modifier.c:410 modifier_setError: Attempt to unbind from inactive dependency graph
Video Demo
If I throw in a Mesh Deform mod as well, there will be a new error (bind, instead of unbind)
ERROR (bke.modifier): /home/sources/buildbot-x86_64-slave/linux_glibc224_x86_64_cmake/blender.git/source/blender/blenkernel/intern/modifier.c:410 modifier_setError: Attempt to bind from inactive dependency graph
MACHIN3 (MACHIN3) updated the task description. (Show Details)
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.May 8 2019, 3:14 PM
Isn't this a duplicate of T64300 ? It seems like depsgraph has issues when redoing.
MACHIN3 (MACHIN3) added a comment.EditedMay 8 2019, 3:22 PM
It may be related, but I'm getting a clear error message from this one here, related to the binding/unbinding of the deformation mods, whereas I can only observe the misbehavior in the other one (and it misbehaves in a different way as well).
I think that merits a separate bug report.
If it can be fixed with a single approach, that would be great of course.
I have the same error:
ERROR (bke.modifier): c:\b\win64_cmake_vs2017\win64_cmake_vs2017\blender.git\source\blender\blenkernel\intern\modifier.c:410 modifier_setError: Attempt to unbind from inactive dependency graph
version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-07 19:17, hash: 3dc9da3a74ee, type: Release
build date: 07/05/2019, 18:30
platform: Windows 10 64bit
gfx - _ Nvidia GTX 1080 Driver - 430.39
Complete system info:
https://pastebin.com/SgL40qup
MACHIN3 (MACHIN3) changed the task status from Unknown Status to Resolved.May 18 2019, 9:24 AM
Like https://developer.blender.org/T64300, this has now also been fixed by rBbe5fd9c09f25. Thank you @Sergey Sharybin (sergey)! Closing.
