Normals Workflow #64324
6 Participants
Reference: blender/blender#64324
Recently, Blender gained some new abilities related to manipulating custom normals. However, the UI to control these leave a lot to be desired.
We want to improve this workflow and UI configuration. Here's how:
Additionally, in a later release we could add a Normals tool in the toolbar, with tool properties to set the sub-tool. This could make it easier to 'paint' normal directions on the mesh.
Added subscribers: @WilliamReynish, @ideasman42
Added subscriber: @howard
Added subscriber: @howardt
Removed subscriber: @howard
I agree with most of this, and have been working on it. With changes I made to the normal menu, I can now remove Face Strength from the Normals panel in Tool properties.
I initially was going down the path of putting the Normal Vector in the Item Transform panel, but it is somewhat problematic, so withdrew that idea. The reason is that it feels incompatible with the other uses of value boxes in the Item Transform panel, which as I understand it follow the paradigm of: they always reflect the value of the current selection's property (perhaps a median value), and if you change the box, it should immediately change the value of the property (in this case, the normal vector of the implicitly selected normals). One important case that this misses is the Copy/Paste scenario: you select one normal, copy it to the "Normal Vector" box (really, a scratch buffer for normals), and then select a different set of normals and paste that value back. [Actually, such a feature would be cool for other properties in the Item Transform Panel, but doesn't exist right now.) Further, the Add and Multiply functions need a separate value from the scratch buffer. I asked on forums whether people actually use those -- answer was unclear, though someone posted a video showing some weird use of this to affect NPR shading. We could consider dumping Add and Multiply, I suppose. Even Copy/Paste (requiring people to write down values on paper or somewhere and manually enter them again after changing selection). But would really like to keep at least Copy/Paste. I was pursuing idea of making a Normals tool and keeping the Scratch buffer in the tool properties (and there are a few other Normal tools that have some controller properties, not currently exposed except in Redo panel). I haven't gotten very far yet, and if Campbell wants to do this, I'd be fine with that. But also fine to try to keep on myself.
@howardt We think we might want to change the Normal Vector number field to actually reflect what you select, just like other things in the Transform panel. That was the idea during the UI meeting we had this morning. Does that make sense?
Maybe I'm dense but I can't see why we would need a special separate value field just for copy/pasting? I mean, we could keep the copy/paste operators of course, but don't see why we need persistent fields to hold the clipboard, if you will.
@WilliamReynish Yes, I can see that (the copy/paste buffer being elsewhere and hidden).
What were the thoughts about Add/Multiply? Dump them?
@howardt I suppose we could keep them but just let the user type in a value in the redo panel.
One question about the idea of making the normal vector in the transform tools item panel be a live reflection of the current selection: this is a not-inexpensive operation (see BM_loop_normal_editdata_array_init in bmesh_mesh.c: it allocates several #loop-length things and iterates over all the loops of the mesh). Even if we only do this if there are custom normals, is there any concern about doing this every time a selection changes? I don't think so, but wonder what others think before going down this coding path.
Suggest to first try add a tool in the tool-system for this instead of buttons in the items panel.
This is something users want to edit visually, since numbers as directions are only practical for axis-aligned values.
Having buttons that stay up to date is going to be a heavy operation (users may run into noticeable slow-downs if they happen to leave the panel visible).
Even though the tool updates will be heavy too, at least it will be limited to when the tool is in use.
Added subscribers: @mont29, @brecht
Computing the median normal indeed seems expensive. It may not be too terrible in practice as custom normals are mostly used for relatively low poly meshes, and it could be in a subpanel that is collapsed by default. But still, it can be an issue.
Just removing the Add and Multiply tools may be ok. If we want to keep that functionality, we could add an "Edit Value" operator, that shows you a popup with the median normal that you can then edit. Not as elegant as a panel, but same functionality without the performance concern.
I guess what this means is that it would enable Auto-Smooth automatically along with adding the Custom Split Normals Data? Ideally Autosmooth and Use Custom Normals should be separate settings, it's not obvious to users that they are related. Probably not a big change, but not sure there is time for it.
Custom lnors data is already automatically added by the operators when needed, afaik. So it’s only a matter of enabling autosmooth too, when needed, that should be a rather trivial change? We could also do it when adding one of the normal editing modifiers, actually…
Currently the normals menu commands all have a poll that tests for autosmooth being on. That poll should be removed and the code should just test and turn it on if not already on when those menu items are invoked. I looked once at doing this automatically in the bevel modifier when harden normals was chosen but it was annoying to do because the bevel code is all in a file that only operates on BMesh and there is no autosmooth option recorded in BMesh that could be set and propagated back to the Mesh in the modifier code. This could be corrected, of course.
I think that this task is complete for now. We should start a new task for a real tool in the toolbar for a 2.81 or later. Since such tools are typically interactive, some possibilities would be:
Added subscriber: @AlbertoVelazquez
@howardt
I have seen that add/multiply or paste a custom vector was removed when is one of the main applications? why it was done? It's remove a big feature of the custom normals.
It would require a whole new UI to do (to have an entry box for the thing to add or multiply by or set for pasting. We couldn't figure out an good way to do that in the time before 2.80, so went with what we went with. As noted above, probably a real tool should be made with some good UI design. One can still copy a normal from somewhere else (constructed as one sees fit) and paste it. And the functionality is still available via Python.
Also, I asked in one of the user forums if people would miss the add/multiply, and almost no-one said they would. The one case someone pointed out seemed a pretty dubious toon shading application (why one would use multiplication in that case rather than just set the normals to a particular value was not at all clear).
I think that the impression that it is not useful is wrong. Most people didn't know the tool by that moment, but also is a important feature for a lot of situations where you need add precise normals
The ui had 2-3 proposals for that but the ui team told that they will see in a future.
old proposal that solve the problem using the same idea that vertex groups weights
