Module 'aud' has no attribute 'device'
Closed, InvalidPublic
Operating system:linux 64bit
Graphics card:
Broken: (example: 2.80, 7c9e649015d4, master, 2019-05-09, as found on the splash screen)
when i run script :
import aud
device = aud.device()
# load sound file (it can be a video file with audio)
factory = aud.Factory('music.ogg')
# play the audio, this return a handle to control play/pause
handle = device.play(factory)
# if the audio is not too big and will be used often you can buffer it
factory_buffered = aud.Factory.buffer(factory)
handle_buffered = device.play(factory_buffered)
I received an error message : AttributeError: module 'aud' has no attribute 'device'
And the sound will not play.
Joerg Mueller (nexyon) closed this task as Invalid.May 10 2019, 9:34 AM
Blender 2.8 uses the latest version of audaspace where the aud API has changed considerably, please refer to the audaspace bindings API documentation.
