Surface Deform Modifier Not Rendering Properly in Cycles #64472
Reference: blender/blender#64472
Graphics card: AMD Radeon (TM) R9 390 Series ATI Technologies Inc. 4.5.13547 Core Profile Context 25.20.15027.1003
Broken: version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-10 09:55, hash:
196dbc0f31
Worked: (Blender 2.79)
The Surface Modifier is not showing in the final render in Cycles. It only appears to render fine during the preview mode. I have attached an image that illustrates the issue.
Added subscriber: @JorgeMolina
Added subscriber: @brecht
We need a simple .blend and steps to reproduce the problem, a screenshot is not enough information for us to investigate.
Hello,
Not a problem, here is a blend file that you can use. :)
oldWarrior_2.8_issue.zip
I tried to reproduce the problem in a new file and I couldn't. It seems like there is an issue with this file in particular, but I can't figure out what it is. The original file worked well in Blender 2.79.
Thank you,
Added subscriber: @sozap
The issue append because objects with surface deform are binded to a mesh with a subsurf that is different from viewport and render.
Activating subsurf on 'oldWarrior_body' disable surface deform on other objects. It's not a bug but how surface deform is working.
Surface deform is quite effective to rig some objects , but depending how it's binded it's get disabled on the viewport ( like when using simplify) or (like in your case) at rendertime .
You may try to have two surface deform : one for viewport that is binded to 'oldWarrior_body' without subsurf, and one enabled at rendertime that is binded to "'oldWarrior_body" with subsurf activated...
You may have changed settings bettwen 2.79 and 2.8 because this behaviour as always been there.
Thank you for the solution! It makes sense. It works now. I really appreciate the time and the effort. Thank you again :)
This is a source of confusion that we should try to address once, but indeed it's not a bug then.
Added subscriber: @gurlaldeep
hey I am having the same problem but I did not understand the your solution
i have surface deform active on all layers
