Image Crop in VSE Stretches Image Instead of Cropping #64485
Closed
opened 2019-05-11 14:28:09 +02:00 by Bruce Gates · 7 comments
Operating system: Windows 10
Graphics card: Intel HD Graphics 4000
Broken: 2.79b, Date: 2018-03-22 14:10, Hash: f4dc9f9d68 as found on the splash screen
When trying to crop a movie clip, the image stretches instead of cropping. I saw a previous post in which someone indicated that this only happened when Image Offset was also checked but in my case, this behavior is happening with Image Offset unchecked. If I check Image Offset, the behavior changes. If Image Offset is checked, the image is shifted in the direction in which I am trying to crop, effectively "sliding" the image to that side of the frame. This is not how I recall the crop feature working previously...
Open VSE
Import movie clip
In Strip tab, click "Image Crop"
Make any adjustment to Top, Left, Right, or Bottom
**System Information** Operating system: Windows 10 Graphics card: Intel HD Graphics 4000 **Blender Version** Broken: 2.79b, Date: 2018-03-22 14:10, Hash: f4dc9f9d68b as found on the splash screen **Short description of error** When trying to crop a movie clip, the image stretches instead of cropping. I saw a previous post in which someone indicated that this only happened when Image Offset was also checked but in my case, this behavior is happening with Image Offset unchecked. If I check Image Offset, the behavior changes. If Image Offset is checked, the image is shifted in the direction in which I am trying to crop, effectively "sliding" the image to that side of the frame. This is not how I recall the crop feature working previously... **Exact steps for others to reproduce the error** Open VSE Import movie clip In Strip tab, click "Image Crop" Make any adjustment to Top, Left, Right, or Bottom
Author
Added subscriber: @OpenDm
Author
Physis_Ad.blend
Attached are some supporting files: two images that show the before-and-after of the effect of cropping with Image Offset unchecked and the Blender Project I am working on.
I should note that I am seeing this in all of my projects.
![crop.png](https://archive.blender.org/developer/F7028187/crop.png) ![Precrop.png](https://archive.blender.org/developer/F7028186/Precrop.png) [Physis_Ad.blend](https://archive.blender.org/developer/F7028190/Physis_Ad.blend) Attached are some supporting files: two images that show the before-and-after of the effect of cropping with Image Offset unchecked and the Blender Project I am working on. I should note that I am seeing this in all of my projects.
Added subscriber: @sozap
This is how it's supposed to work,
When you add an image to the VSE it gets automatically scaled to the output resolution .
When you crop it , cropping append before scaling. That's why it can give the impression of the image sliding when changing crop values.
Checking image offset will preserve the original format of the image, then you can crop it and move it as you wish.
This is how it's supposed to work, When you add an image to the VSE it gets automatically scaled to the output resolution . When you crop it , cropping append before scaling. That's why it can give the impression of the image sliding when changing crop values. Checking image offset will preserve the original format of the image, then you can crop it and move it as you wish.
Added subscriber: @brecht
Brecht Van Lommel self-assigned this 2019-05-14 01:14:35 +02:00
Agree, I think that's how it works even if it's not obvious.
Reference: blender/blender#64485
