Old and standard behavior gone from navigation while Gizmo's active. #64517
Reference: blender/blender#64517
bSystem Information
Graphics card: GeForce GTX 760/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.94
Broken: version: 2.80 (sub 61), branch: blender2.7, commit date: 2019-05-10 22:48, hash:
b1af682001
Please watch the video that demonstrates the problem. Thank you.
2.8_GIZMO.mp4
Added subscriber: @ajlanaltug
Closed as duplicate of #60984
Added subscribers: @ideasman42, @WilliamReynish
You should probably clarify that you are not using the default keymap - at least I am guessing you are not, because by default this is not a problem.
It is an issue if you use Maya-style Alt-dragging for the viewport, because the gizmos are invoked with any modifier key pressed.
@ideasman42 Not sure where to set this but I am guessing it should be a relatively easy fix?
Changed status from 'Duplicate' to: 'Resolved'
Sorry I forgot to point that out but yes, you nailed it; I am using a different navigation keymap other than the default, and yeah it's an Alt driven navigation keymap. Since the previous version of Blender could do this without a hitch, I take it that it's successor could do it as well. May I ask why it's been labeled as "Resolved" tho? Does this mean that it will be fixed in a coming daily build?
Thank you;
AJ
If you use your own keymap you may need to fix it there yourself. But if you use either of the built-in keymaps, it should work correctly now.
The Industry Compatible keymap is Alt-driven and now works correctly.
snip"If you use your own keymap you may need to fix it there yourself"snip
I'm sorry but I really don't know how. Could you elaborate?
Thank you;
AJ
And btw, I switched to the "Industry Compatible" keymap mode just now and the issue still persists in the latest build.
AJ
Ok I dowloaded 2.8 version
27d097e92d
and the "industry standard" preset works. But I want to know how a preset could make this work and a manual assignment won't, where a preset is, uh... A preset, as the word implies. A table of preset values that are set by the user to alter a list of parameters... I checked and all the navigation and transform shortcuts under that preset are completely identical to their counterparts under mine. So what gives?Currently you must set the transform gizmo to not react to Any modifier key.
Added subscriber: @SpectreFirst
If I'm not mistaken, disabling "Any" in this field should do the trick. For some reason I can't find it manually so I'm just using search function by Gizmo
