Drag in empty space to box select does not work in animation editors #64565
8 Participants
Reference: blender/blender#64565
Operating system: Ubuntu 18.10
Graphics card: Radeon RX 560 Series (POLARIS11, DRM 3.31.0, 4.18.0-18-generic, LLVM 7.0.0)example_vse_cache_invalidated.webm
Broken: 2.80,
ebc44aae98
, master, 2018-05-11Short description of error
Cached frames become invalidated as soon as another video strip is selected.
Add two video strips, one above the other. Select one of them and play, to get some frames cached. Then select the other strip and parts of the cache becomes invalidated.
Added subscriber: @JosefR
#65063 was marked as duplicate of this issue
#64961 was marked as duplicate of this issue
Added subscriber: @WilliamReynish
I was about to create this task.
@WilliamReynish is it OK to change sequence move operator to LMB + tweak?
Minor issue also is, when you box select strips and try to move them by mouse - only the one you move will be moved, because others will be deselected
@iss
Afaik that won't work, as tweak is used to box select. Ideally this could work so that if you tweak ON a clip, it moves, but if you tweak outside, it box selects. But the keymap cannot currently make this distinction in that way.
Yes, this is a known issue. It was just solved for the Node editor. This should become generic so we can use it in places like this too.
As for the cache, I guess it really should not be discarded if the clip was never actually moved?
Technically this would solve this, but often I actually move it, then it returns back to position, because it can not move.
Ok so I will do ideally both checks and run invalidation accordingly.
@WilliamReynish
Haven't got too far with this today, but I have noticed, that when you have effects applied on top of a strip, move operator will select whole chain.
This makes it hard to actually select a strip in such case.
So again I would rather make distinction at what I am pointing to when doing LMB+tweak and decide between box select / move.
Not quite sure how exactly I would do this though.
You should be able to check the Node editor which I think does it.
@WilliamReynish
Ok found it #63994 (Node Editor: Move All Selected Nodes when dragging)
To sum up / confirm behavior:
on click:
on click release:
on tweak:
is that correct?
Added subscriber: @mont29
I think that's correct - @mont29 coded this so should be able to confirm.
yes, that’s basically it. But I would advise you wait a bit here, going modal raised some annoying issue (#64660 and #64693 are actually same fundamental problem), that needs to be addressed before generalizing that approach.
Added subscriber: @snuq
Added subscriber: @WayneDixon
Selecting sequencer strips invlidates cacheto Drag in empty space to box select does not work in animation editorsAdded subscriber: @iss
Added subscriber: @brecht
I've reverted the commit that caused this in
244c39f1ab
. It was unusable for video editing and animation, we should first fix it and then enable the behavior again.As far as I know, this bug is not related to "Move All Selected Nodes when dragging" specifically. Even in Blender 2.7 could you box select from empty space in the node editor, without it causing issues like this.
The way this is handled in the node editor is like this:
I think the same fix could work in the sequencer and animation editors.
Implemented it for the sequencer using the approach Brecht mentioned:
8e125f278c
@JacquesLucke, regarding that commit:
244c39f1ab
, assuming they are compatible with this now.@JacquesLucke @brecht Now box select indeed works again, but should we also allow dragging multiple strips, just like we do for nodes? It seems like if we use the Node Editor method we could allow that too.
No, we should focus on stabilizing now, further improvements are for 2.81.
Thx guys for help here!
Do you want to do that or should this be closed?
If I understand this correctly,
marker.select
operator would have to be defined in sequencer region. But thenED_markers_find_nearest_marker
will always return marker if markers are used, which would prevent box select from working, so that would have to be modifiedWe still have to bring box selection for graph/dopesheet/NLA editors as well, they have the same issue.
For markers, what I meant is that
sequencer_box_select_invoke
should also check if the mouse is over any markers before allowing box select to start, to be sure it's really over empty space.Added subscriber: @AbidMaqbool
AFAIK markers are selected in their own area by own operator, so
shouldn't have to do such check.Changed status from 'Open' to: 'Resolved'
b79976a9bd
,8b1ca3ec53
,04bac38731
,ab5219af34
,8e125f278c
