Redo operator tweaking fails after transforming with constrained axis
Operating system: Darwin-18.5.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Plus Graphics 640 Intel Inc. 4.1 INTEL-12.8.38
Broken: version: 2.80 (sub 64), branch: master, commit date: 2019-05-15 17:31, hash: rBfe8f0758c651
Worked: I am pretty sure this worked a month or two ago?
Redo operator tweaking fails for the constrained axes after a transform
  1. Enable the Move tool
  2. Click and drag on the X axis arrow (red)
  3. Open the redo panel that says 'Move'
  4. Attempt to tweak the Z or Y axes.
These properties will fail to be adjusted.
Brecht Van Lommel (brecht) triaged this task as Confirmed, Medium priority.May 21 2019, 8:45 PM
Campbell Barton (campbellbarton) raised the priority of this task from Confirmed, Medium to Confirmed, High.May 22 2019, 4:27 AM
Just to add more information to the proposed error/bug:
Redo operator fails for both Move & Scale operation weather executing with gizmo or directly through key-board in object and edit mode.
Redo operator then works in only those axis only which are modified with operation (e.g. other axis or proprieties not works in redo operator)
Demo:
Rotate operator works correctly
