Sequencer UI doesn't draw properly with some strip types
As of rB86eefefdc1aae2a3ab4160770032671abf55aa30 the sequencer gives Python errors when drawing.
See attached blend file
  File "/src/cmake_debug/bin/2.80/scripts/startup/bl_ui/space_sequencer.py", line 1196, in draw
    str(strip.animation_offset_start),
AttributeError: 'GaussianBlurSequence' object has no attribute 'animation_offset_start'
  File "/src/cmake_debug/bin/2.80/scripts/startup/bl_ui/space_sequencer.py", line 775, in draw
    col.prop(strip.crop, "min_x")
TypeError: UILayout.prop(): error with argument 1, "data" -  Function.data does not support a 'None' assignment AnyType type
  File "/src/cmake_debug/bin/2.80/scripts/startup/bl_ui/space_sequencer.py", line 746, in draw
    col.prop(strip.transform, "offset_x", text="Position X")
