OBJ Import failure (works on 2.79) #64740
Closed
opened 2019-05-17 02:18:16 +02:00 by Henrique Balduino Gonzaga · 13 comments
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.94
Broken: version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-07 19:17, hash: 3dc9da3a74 (splash screen says 3d9da3a74ee)
Worked: 2.79 hash: f4dc9f9d68
Tryed importing a heavy .obj into blender 2.8 and it crashed 3 times.
worked on the first try on 2.79. Then i opened this file on 2.8 with no problem.
The file is a stupid useless heavy export from that piece of junk called SketchUp (someone put 2 bonsai in it that has 18.000 objects as leaves, each).
Probally deleting this bonsai from the file may help importing into 2.8.
But i wonder, if 2.79 could import it, why 2.8 could't?
The .obj for testing is here : Projeto Ape 2019.obj
Warning. It will take some minutes.
**System Information** Operating system: Windows-10-10.0.17763 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 416.94 **Blender Version** Broken: version: 2.80 (sub 60), branch: blender2.7, commit date: 2019-05-07 19:17, hash: `3dc9da3a74` (splash screen says 3d9da3a74ee) Worked: 2.79 hash: f4dc9f9d68b **Short description of error** Tryed importing a heavy .obj into blender 2.8 and it crashed 3 times. worked on the first try on 2.79. Then i opened this file on 2.8 with no problem. **Exact steps for others to reproduce the error** The file is a stupid useless heavy export from that piece of junk called SketchUp (someone put 2 bonsai in it that has 18.000 objects as leaves, each). Probally deleting this bonsai from the file may help importing into 2.8. But i wonder, if 2.79 could import it, why 2.8 could't? The .obj for testing is here : [Projeto Ape 2019.obj](https://archive.blender.org/developer/F7042061/Projeto_Ape_2019.obj) Warning. It will take some minutes.
Added subscriber: @HenriqueGonzaga
Added subscriber: @StephenSwaney
You wouldn't want to give us a hint and show us the error message?
There is no message. Blender just closes.
Sometimes you can trick Blender into revealing secrets by running it from the command line.
I can import your .obj on Linux, but it looks like Blender needs over 2 Gb of memory to do so.
You might try running from the command line and looking for messages about calloc or malloc returns nil.
This is a sign of running out of memory.
Sometimes you can trick Blender into revealing secrets by running it from the command line. I can import your .obj on Linux, but it looks like Blender needs over 2 Gb of memory to do so. You might try running from the command line and looking for messages about calloc or malloc returns nil. This is a sign of running out of memory.
I have 32 Gb of memory..
And if it refers to my GPU, I think it has 4Gb
I don't know how to use the command line.
Just wondered why 2.79 worked and 2.8 didn't..
I have 32 Gb of memory.. And if it refers to my GPU, I think it has 4Gb I don't know how to use the command line. Just wondered why 2.79 worked and 2.8 didn't..
That shoots my lack of memory theory. I got nothing...
> I have 32 Gb of memory.. That shoots my lack of memory theory. I got nothing...
Added subscriber: @mont29
As for using command line… http://www.letmegooglethat.com/?q=windows+command+line
Monster file imports fine for me as well, we cannot do anything else without more info…
As for using command line… http://www.letmegooglethat.com/?q=windows+command+line Monster file imports fine for me as well, we cannot do anything else without more info…
Member
Added subscriber: @Mets
Member
Windows 10, v1607
GTX 1070 latest drivers
16GB RAM
Attempt 1, importing to 2.80, 65168825e0b0:
Huh. I can actually reproduce this. After a minute or two of waiting, blender just closes.
Attempt 2, I started importing to 2.80 and 2.7 at the same time(to save time and test both), this time from command line:
My computer has gone completely haywire, screens started flashing, desktop disappeared, and a few seconds later(not long enough for a reboot) I was greeted by my windows login screen, and all my apps are closed, and only my second monitor works. A PC reboot fixed this.
Attempt 3, importing only to 2.80 again, with command line:
Console output:
(  0.0286 sec |   0.0286 sec) Importing OBJ 'D:\\Met-PC\\Downloads\\Projeto Ape 2019.obj'...
  (  0.1330 sec |   0.1034 sec) Parsing OBJ file...
    ( 32.4876 sec |  32.3542 sec) Done, loading materials and images...
        Material not found MTL: 'D:\\Met-PC\\Downloads\\Projeto Ape 2019.mtl'
    ( 36.5409 sec |  36.4074 sec) Done, building geometries (verts:1114038 faces:1191721 materials: 8387 smoothgroups:0) ...
    ( 53.8666 sec |  53.7331 sec) Done.
  ( 53.8676 sec |  53.8380 sec) Finished importing: 'D:\\Met-PC\\Downloads\\Projeto Ape 2019.obj'
Progress: 100.00%
Calloc returns null: len=20296032 in GPUIndexBuf data, total 4249401996
Calloc returns null: len=20296032 in GPUIndexBuf data, total 4249401996 (repeated thousands of times)
Calloc returns null: len=20296032 in GPUIndexBuf data, total 4289994060
Calloc returns null: len=20296032 in GPUIndexBuf data, total 4289994060 (repeated thousands of times)
Calloc returns null: len=20296032 in GPUIndexBuf data, total 15322796
Calloc returns null: len=20296032 in GPUIndexBuf data, total 15322796 (repeated thousands of times)
Error   : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF6875F9F28
Module  : D:\3D\Blender\blender-2.80.0-git.65168825e0b0-windows64\blender.exe```
Additionally, windows threw this in my face: {F7614837}
And my PC started doing some funny things for a few seconds(browser tabs and desktop icons disappearing) but recovered. This makes me think there is something memory related going on here afterall, which could help explain attempt #2.
**Attempt 4, Blender 2.7**
I actually can't seem to import this into 2.7 either. Although it's hanging at 33% instead of crashing and making my PC lose its mind. Tried multiple times, waited upwards of 5 mins.
```(  0.0000 sec |   0.0000 sec) Importing OBJ 'D:\\Met-PC\\Downloads\\Projeto Ape 2019.obj'...
  (  0.0010 sec |   0.0000 sec) Parsing OBJ file...
    ( 33.5557 sec |  33.5542 sec) Done, loading materials and images...
Progress:  33.33%```
Windows 10, v1607 GTX 1070 latest drivers 16GB RAM **Attempt 1**, importing to 2.80, 65168825e0b0: Huh. I can actually reproduce this. After a minute or two of waiting, blender just closes. **Attempt 2**, I started importing to 2.80 and 2.7 at the same time(to save time and test both), this time from command line: My computer has gone completely haywire, screens started flashing, desktop disappeared, and a few seconds later(not long enough for a reboot) I was greeted by my windows login screen, and all my apps are closed, and only my second monitor works. A PC reboot fixed this. **Attempt 3**, importing only to 2.80 again, with command line: Console output: ``` ( 0.0286 sec | 0.0286 sec) Importing OBJ 'D:\\Met-PC\\Downloads\\Projeto Ape 2019.obj'... ( 0.1330 sec | 0.1034 sec) Parsing OBJ file... ( 32.4876 sec | 32.3542 sec) Done, loading materials and images... Material not found MTL: 'D:\\Met-PC\\Downloads\\Projeto Ape 2019.mtl' ( 36.5409 sec | 36.4074 sec) Done, building geometries (verts:1114038 faces:1191721 materials: 8387 smoothgroups:0) ... ( 53.8666 sec | 53.7331 sec) Done. ( 53.8676 sec | 53.8380 sec) Finished importing: 'D:\\Met-PC\\Downloads\\Projeto Ape 2019.obj' Progress: 100.00% Calloc returns null: len=20296032 in GPUIndexBuf data, total 4249401996 Calloc returns null: len=20296032 in GPUIndexBuf data, total 4249401996 Calloc returns null: len=20296032 in GPUIndexBuf data, total 4249401996 (repeated thousands of times) Calloc returns null: len=20296032 in GPUIndexBuf data, total 4289994060 Calloc returns null: len=20296032 in GPUIndexBuf data, total 4289994060 Calloc returns null: len=20296032 in GPUIndexBuf data, total 4289994060 (repeated thousands of times) Calloc returns null: len=20296032 in GPUIndexBuf data, total 15322796 Calloc returns null: len=20296032 in GPUIndexBuf data, total 15322796 Calloc returns null: len=20296032 in GPUIndexBuf data, total 15322796 (repeated thousands of times) Error : EXCEPTION_ACCESS_VIOLATION Address : 0x00007FF6875F9F28 Module : D:\3D\Blender\blender-2.80.0-git.65168825e0b0-windows64\blender.exe``` Additionally, windows threw this in my face: {F7614837} And my PC started doing some funny things for a few seconds(browser tabs and desktop icons disappearing) but recovered. This makes me think there is something memory related going on here afterall, which could help explain attempt #2. **Attempt 4, Blender 2.7** I actually can't seem to import this into 2.7 either. Although it's hanging at 33% instead of crashing and making my PC lose its mind. Tried multiple times, waited upwards of 5 mins. ```( 0.0000 sec | 0.0000 sec) Importing OBJ 'D:\\Met-PC\\Downloads\\Projeto Ape 2019.obj'... ( 0.0010 sec | 0.0000 sec) Parsing OBJ file... ( 33.5557 sec | 33.5542 sec) Done, loading materials and images... Progress: 33.33%```
Bastien Montagne self-assigned this 2019-07-17 15:03:21 +02:00
@Mets that’s lack of available RAM (or GPU RAM, code fails to allocate needed memory). Not much to be done here, besides general optimization of Blender. but that is not a bug afaiks.
In any case, no answer from OP since over a month, more than time to archive.
@Mets that’s lack of available RAM (or GPU RAM, code fails to allocate needed memory). Not much to be done here, besides general optimization of Blender. but that is not a bug afaiks. In any case, no answer from OP since over a month, more than time to archive.
Reference: blender/blender#64740
