to_mesh() for evaluated object not work with shape key
Graphics card: GeForce GTX 980 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.64
Broken: version: 2.80 (sub 67), branch: master, commit date: 2019-05-16 13:21, hash: rBbd0f26e2de7b
Worked: 2.7 and other 2.80 versions untill new dependency update
evaluated object , to_mesh() not return mesh which armature modifier applied when original object have shape keys
1 load attached blend file. then go to Script work space. (if not)
2 select "cylinder" which deformed by armature modifier and no shape key.
3 Run registered test.py script. ( it generate new obj named as cylinder_clean .)
(or download attached test.py and load test.py in script editor, then Run script )
4 confirm generated new object is armatrue modifier applied, and same shape of "cylinder"
(so to_mesh work as expected for evaluated object)
5 to keep view clean, hide the cylinder_clean, and cylinder objects.
6 select "cylinder_keys" which deformed by armature modifier , but basis shape key are added. (copied object of "cylinder", just add basis shape key so they are identical objects)
7 run script. it generate new obj named as cylinder_key_clean
8 the new generated obj are not applied armature modifier. (as if it remove modifier not applied)
untill e693918d4074
" to_mesh()" could generate mesh which modifier and current shape key values applied with option.
(mesh = obj.to_mesh(bpy.context.depsgraph, True)
and it was important function to get same mesh as view. but at current there seems no alternative way to achieve same thing. (shape key + modifier apply)
Then after generate Cylinder_keys_clean, , remove shape key (basis) from
Cylinder_keys (original mesh), and run-script again, blender 2.8 shut down too.
(there already clash report about evaluated obj , to_mesh() , T64731 T64735
so I think the clash of my case is related too.
Have you tried bpy.data.meshes.new_from_obj(obj_eval)?
MACHIN3 thanks advice. then no. I just tried to use to_mesh() for up-date some add on for 2.8
. so I need to use bpy.data.meshes.new_from_obj(obj_eval) for the purpose?
If it can do same thing which I could by (obj.to_mesh(bpy.context.depsgraph, True)) I apreciate.
before it worked with true option.
Then could you take time to edit my really simple test.py to work so? or tell me link etc,
of sample script which use new_from_obj? (just apply current shape key values, with modifier)
Thanks MACHIN3 it worked to generate mesh which shape keys mix value + armature modifier applied
mesh = bpy.data.meshes.new_from_object(obj_eval) is alternative of removed " obj.to_mesh(depth, True)"?
MACHIN3 (MACHIN3) added a comment.EditedMay 17 2019, 12:22 PM
Check out was Sergey told me:  https://developer.blender.org/T64735#681264
Basically, if you want to use the evaluated mesh as part of the blend file, for instance by assigning it to some obj.data, you need to use bpy.data.meshes.new_from_obj(obj_eval) now.
to_mesh() can still be used, if you want to do math on the mesh, or perhaps for bmeshes as well, I'm not sure yet. If you do use to_mesh(), note that it doesn't have any arguments anymore, it's just to_mesh().
The result of to_mesh() is shortlived, it doesn't stay around, hence why you can't use it for obj.data
Also see https://developer.blender.org/rB32d5d127cb49743578e8e1e9882d8a707a4e848e and https://developer.blender.org/rB5186cfbea4c1c1111d6e6061ab877ee8d9b4f206
I see, really thanks you take time to guide me details ^^
when I saw this depthgraph up-date ,I afraid I will lost way for shape key. then reported it and asked first.
on https://developer.blender.org/rBe693918d40741b0839cea84d2e0c386cc262e0c3
because I know when apply modifier, I need to apply shape keys, (if do it from blender UI) but it is not good when I need to re-use the original .or I need to keep copy. then hoped answer from developer.
Anyway I could get answer from you, and Now I can clear understand how it will work.
Happy to help. Good luck.
Note: started the patch which is aimed to help spotting such mistakes more easily: D4884.
