Startup crash in versioning for some users after bc3139d79226 Eevee DOF Unification
Graphics card: GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.17
Broken: version: 2.80 (sub 69), branch: master (modified), commit date: 2019-05-17 17:00, hash: rBbe5fd9c09f25
Worked: Reportedly builds prior to current buildbot.
Blender crashes on startup in versioning code.
Reported by two people in https://blender.chat/channel/support and I reproduced it here using the supplied .blend
User supplied startup.blend: https://dropbox.com/s/z5hovcne4ue2gfq/startup.blend?dl=0
Using this user-supplied startup.blend will result in a crash on startup. You can simply try opening the file as a normal .blend and it will also crash, so you don't need to put it in place as the actual startup file.
Abort location below. The scene data structure does not look valid and the cam_ob->type reference faults.
    /* Unify DOF settings (EEVEE part only) */
    if (!DNA_struct_elem_find(fd->filesdna, "Camera", "CameraDOFSettings", "dof")) {
      const int SCE_EEVEE_DOF_ENABLED = (1 << 7);
      LISTBASE_FOREACH (Scene *, scene, &bmain->scenes) {
        if (STREQ(scene->r.engine, RE_engine_id_BLENDER_EEVEE)) {
          if (scene->eevee.flag & SCE_EEVEE_DOF_ENABLED) {
            Object *cam_ob = scene->camera;
-->         if (cam_ob && cam_ob->type == OB_CAMERA) {
              Camera *cam = cam_ob->data;
              cam->dof.flag |= CAM_DOF_ENABLED;
Likely related to: https://developer.blender.org/rBbc3139d79226896cf6c2b0813a1188eda70fad09
Not sure if this matters, the submitted startup.blend camera properties use
bpy.context.object.data.dof_gpu.fstop (I think)
bpy.context.object.data.dof_gpu.blades
bpy.context.object.data.dof_gpu.focus_distance
vs the new properties:
bpy.context.object.data.dof.aperture_fstop
bpy.context.object.data.dof.aperture_blades
bpy.context.object.data.dof.focus_distance
The link to the startup.blend is dead? I have an idea what might be causing it though.
Sorry, here it is: https://www.dropbox.com/s/e3x6h5h3awicaig/startup.blend?dl=0
For future reference, when you have files, you can just drag them into the text area and they will be uploaded and attached to the bug report, no need to host them on other sites.
