Push the Space Bar key for Mac only. #64786
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#64786
Please do use Macintosh. Do not use Windows.
May 17, 2019 Blender 2.80
I just found out why.
When push the Space Bar can appear list within cube object is there.
Push the 'x' key remove cube then push the Space Bar is error say Dynamic Context Menu.
I ready backup on Library/Application Support/Blender/2.80 folder and remove 2.80 folder then open I test and I just found out to tell you.
Blender 2.80 add-ons Push the 'Space Bar' key
Added subscriber: @Kent-Davis
Added subscriber: @jenkm
Are you use Macintosh yet?
Blender 2.79b it work very good while push the 'Space Bar' key while delete cube..
Blender 2.80 error while push the 'Space Bar' key while delete cube.
Added subscriber: @brochignac
I have exactly the same error under Linux, Kubuntu 19.04, add-on Dynamic Context Menu v1.9.1.
and
My startup file have no cube, only the camera and the light.
When I open a new file and I press the space bar, the "Dynamic Context Menu" is empty.
I have to select an object (camera or light for me) to have the normal "Dynamic Context Menu".
If I delete the selected objet, the "Dynamic Context Menu" is empty again.
This issue was referenced by
2ce7a5d85c
Good job! I am proud of all of you deeply inspect about bug.
Added subscribers: @brecht, @BrendonMurphy
Thanks, I had been wanting solve this issue, thanks for reporting and thanks @brecht for the correct fix.
Sure no problem. I had been send report ticket many times
Today download May 18, 2019
Push the Space Bar key is PASS (Solve problem and fixed.)
