Eevee 'leaks' light across opaque surface while cycle renders properly
Closed, InvalidPublic
Operating system: Ubuntu 19.04
Graphics card: GeForce GTX 1050 Ti
Broken: 2.80, revision be5fd9c09f2
Full disclosure: I'm not sure if it's a limitation of the Eevee engine, or a bug, but it sure looks like a bug :)
When rendering using the Eevee engine, lights leaks through opaque surface placed in between a light source and the camera/view angle; cycle renders properly.
  • Open the attached .blend file
  • Make sure Eevee engine is selected
  • Switch to rendered view
  • Notice the light wrongly going through the rough of the opaque box, as well as through the opaque wall where a cube is intersecting.
This is a simple .blend file showing the light leaks:
This is a screen capture in rendered view with the eevee engine, follow yellow arrows to spot the leaks:
This is a screen capture in rendered view with the cycle engine, with no light leaks:
Clément Foucault (fclem) closed this task as Invalid.
Clément Foucault (fclem) claimed this task.
This is a limitation of shadow maps. The contact shadows can help but are not a silverbullet.
To workaround this problem add thickness to your walls and increase the shadow bias parameter.
