"Batch-Generate Previews" crashes #64827
Reference: blender/blender#64827
Operating system: Windows 10 Home x64
Graphics card: GTX 970M
Broken: 2.80.69,
06c4139a68
(2019-5-19)Short description of error
The operator to batch generate previews is broken. It ends up with a console window with the error, but it can't be closed and the ui window is completely normal. It also says "Blender quit."
Added subscriber: @MrGrapeDave
Added subscriber: @lichtwerk
Yep, this was left out from
77f92b8cb7
. (still wanted to check something).This issue was referenced by
1d2e4c44bd
Changed status from 'Resolved' to: 'Open'
(Version: 2.8 Release Candidate 1)
This issue is still present in the form of either another command prompt message, or it doesn't say anything and no previews are generated when viewing them when appending.
Some files, like the default one, shows this message and writes the previews, but most don't write when that comes up.
I noticed a memleak in D4917 as well, this I will track down [this should not be the reason for not writing the previews though...and is probably not that high priority atm...].
However, I cannot reproduce the issue of "it doesn't say anything and no previews are generated when viewing them when appending":
I ran this on multiple files and the previews seem to show:
*NOT* Saving someblendfile.blend, because some error(s) happened while deleting temp render data...
(or any other ERROR message)?That message is what I was talking about at the end of the second comment. Here is that message with wasp_bot.blend from 2.8's page on blender.org .
I also can't quite remember what I did to get it to fail and not say anything.
OK, get it, too, (on the
race_spaceship.blend
) if I removetry
/except
, it fails here:Here it seems to be about
UnitSettings
.length_unit
[this might be more general though and affect other properties which have changed?]Checking further...
8a5a8282ce
Added subscriber: @mont29
I think this is due to settings with bad/missing do_versions code?
Those values are empty in the failing files and then this empty value refuses to be set (e.g. on an enum)
seems like this fails for (again, I've disabled try/exept in
rna_backup_restore
):UnitSettings
(length_unit
, ...), introduced in2d21eb79ad
ERROR:bpy_struct: item.attr = val: enum "" not found in ('ADAPTIVE')
FFmpegSettings
(ffmpeg_preset
, ...), introduced in7e39d151d8
, fails withERROR: bpy_struct: item.attr = val: enum "" not found in ('BEST', 'GOOD', 'REALTIME')
, not sure about FFM_PRESET_NONE in code...@mont29: do you have a quick solution to this? Just skip them in
exclude_props
(D5255)?Changed status from 'Open' to: 'Resolved'
@MrGrapeDave next time please open a new task, that new issue you are reporting here has absolutely nothing in common with the original one (except for the fact that they affect the same end-user tool), having different issues in a single task is really not ideal to manage the tracker.
125e0cfb25
f3899c13cd
