Active point of Curve objects is not displayed correctly #64829
6 Participants
Reference: blender/blender#64829
Operating system: Darwin-18.2.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 455 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.4.10
Broken: version: 2.80 (sub 69), branch: blender2.7, commit date: 2019-05-18 17:13, hash:
1fce0460d5
The active point of the Curve/Surface objects is not displayed correctly (not highlighted in white) after you change it.
Added subscriber: @jenkm
Added subscriber: @nacioss
It is displayed in green as it should be. They changed the color of active verts to be green.
@nacioss green it's just selected points, active one is white
Added subscriber: @lichtwerk
note: seems to update (to white) if you actually move the active point...
...but not if you use the select tools [box, lasso, ...] ...
Added subscribers: @fclem, @ideasman42
I followed this a bit, so DEG seems to be tagging correctly
ID_RECALC_SELECT
,BKE_curve_batch_cache_dirty_tag
gets called...Maybe @fclem or @ideasman42 (campbell: will assign to you first if OK?) know what's going on?
Added subscribers: @Sergey, @JacquesLucke
@Sergey, the issues seems to be that when tagging the curve with
ID_RECALC_SELECT
,cu->actvert
is not copied to the curve-copy in the depsgraph. Is there a place where this just has to be added?@JacquesLucke,
BKE_curve_copy_data()
would be my first guess.Thanks. Unfortunately,
BKE_curve_copy_data
is not called whenID_RECALC_SELECT
is used inED_curve_editnurb_select_pick
. However, it is called whenID_RECALC_ALL
is used.Short answer: use
ID_RECALC_COPY_ON_WRITE | ID_RECALC_SELECT
.Long answer: due to some historical reasons batch cache component (where selection is living) is not making CoW component to be run (was a measure to speed up updates on materials). Using explicit tag should solve this. And then in the future we can have a more closer look and hide CoW specifics from the "user space".
Can confirm
works.There is still an issue when the curve has multiple nurbs [highlighting only works in the very first], as well as the issue with the other selection tools [box, lasso, ...].
Will check on these...
This issue was referenced by
24b2fe50f3
@lichtwerk, then please also commit the fix mentioned by sergey.
