Metaballs are not scaled properly on small values #64952
5 Participants
Reference: blender/blender#64952
Graphics card: GeForce GTX 980 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 425.31
Broken: version: 2.80 (sub 60), branch: master, commit date: 2019-04-30 10:55, hash:
e8daa61570
Applying scale to small metaballs causes object to jump to big values on X axis.
I want to create metaball-man made of bubbles. Bubbles have about 5-10 centimeters, so I want to scale my metaball and then apply scale so my textures are applied correctly instead of being shrinked down.
But I can't make metaball to shrink in X dimension. It stays very large. Y and Z scales properly.
With the attached .blend just apply scale and see how it jumps to big size.
metaballs.blend
Added subscriber: @Acrivec
Added subscriber: @EitanSomething
I don't have a problem scaling the cylinder on the x axis.Can you try on the latest build.If it is still a bug can you share a video bug because I might being doing the scaling in a different way than you.
@EitanSomething pardon that grabbing but I've spend last couple of weeks in Unreal Engine ;p
2019-06-06_14-43-14.webm
What button are you pressing to get the Apply menu. When I right click I get the Object Context Menu
@EitanSomething shift+a, eventually spacebar search menu->apply
Added subscriber: @ZedDB
It seems like scaling is not applied correctly unless the scale is uniform.
Added subscriber: @Jeroen-Bakker
Not sure what you expect. Applying non uniform scaling to meta balls would always leave artifacts. The actual base form is a pill and transformed to a cylinder. When applying the transform the pill will appear again. Note2: a pill only has a single size, so can only apply a single axis so it is more which one. Also I am not sure about the usecase for applying scaling during meta ball editing. Best to convert to mesh and continue from there with regular modeling.
Anyhow, mark this report as Invalid as it works as intended.
I do not agree. It is clearly not working as expected.
you tell me to convert it to mesh... I'm using metaballs for a reason.
I love to report blender bugs. It feels so pointless to do it.
But I know it's already lost because you've said so, and there's no point of arguing. You can close it.
Guess the only fix will be to use other unit scale and scale make it as I want without going for small scale values, which does not cause this bug to appear. Hope unit scale does not screw thin film interference.
Added subscriber: @zeauro
When you enter into Edit mode, capsule shape is defined by an internal Size X setting.
When you apply Scale to this object, you are transferring modification from object mode to this value.
So, resulting capsule length is longer or shorter.
But by doing that, you remove scaling done on meshing of tips of capsule.
And tips are becoming rounder as hemispheres because that is only shape, Blender allows them to have.
No developer never created settings to control aspect of tips of capsule for Blender metaballs.
So, it is a limitation of design of metaballs in Blender. It is not something that was ever supported.
If you want to have flat tips, you have to combine this metaball primitive with other ones.
For example, by adding negative planes or cubes at tips of capsule, you can obtain a similar shape.
Man, this report is about metaball changing it's dimensions on it's own, not about the flat caps. Sigh.
Removed subscriber: @EitanSomething
