stl file exporting #64955
Closed
opened 2019-05-21 17:43:11 +02:00 by Huzaifa · 4 comments
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
when export stl files from blender the scale is reduced by a 100 times
import a blender file.
set the scene units to mm from meter. (doesn't matter)
export file and open in 3D slicer software specifically 3Dgence slicer.
then the file is reduced by x100 when opened up.
**System Information** Operating system: Graphics card: **Blender Version** Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** when export stl files from blender the scale is reduced by a 100 times **Exact steps for others to reproduce the error** import a blender file. set the scene units to mm from meter. (doesn't matter) export file and open in 3D slicer software specifically 3Dgence slicer. then the file is reduced by x100 when opened up. Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @ZexScal
Added subscriber: @Gvgeo-1
George Vogiatzis self-assigned this 2019-05-21 18:18:43 +02:00
Stl does not include unit used.
Normally the program you import would ask for the unit to use.
If you want to match the programs expected value:
  1. Either change scene unit scale
  2. Or change the scale when export.
Stl does not include unit used. Normally the program you import would ask for the unit to use. If you want to match the programs expected value: 1. Either change scene unit scale ![000130.png](https://archive.blender.org/developer/F7058120/000130.png) 2. Or change the scale when export. ![000129.png](https://archive.blender.org/developer/F7058119/000129.png)
2 Participants
Reference: blender/blender-addons#64955
