Crash when Rendering (F12)
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 399.24
Broken: version: 2.80 (sub 71), branch: master, commit date: 2019-05-23 14:37, hash: rBfd3f75a02cf9
Open blender, open my file then crash when Rendering (F12)
I'm not sure but it can be related to track to constraint on the main camera. When I remove this constraint, it doesn't crash for me
George Vogiatzis (Gvgeo) triaged this task as Confirmed, Medium priority.
From build_object function, &object->id is NULL
 	blender.exe!DEG::Depsgraph::get_cow_id(const ID * id_orig) Line 289	C++                <---CRASH
 	blender.exe!DEG::DepsgraphNodeBuilder::get_cow_id(const ID * id_orig) Line 297	C++
 	blender.exe!DEG::DepsgraphNodeBuilder::get_cow_datablock<Scene>(const Scene * orig) Line 94	C++
 	blender.exe!DEG::DepsgraphNodeBuilder::build_object_constraints(Object * object) Line 783	C++
 	blender.exe!DEG::DepsgraphNodeBuilder::build_object_transform(Object * object) Line 748	C++
>	blender.exe!DEG::DepsgraphNodeBuilder::build_object(int base_index, Object * object, DEG::eDepsNode_LinkedState_Type linked_state, bool is_visible) Line 561	C++
 	blender.exe!DEG::DepsgraphNodeBuilder::build_nodetree(bNodeTree * ntree) Line 1385	C++
 	blender.exe!DEG::DepsgraphNodeBuilder::build_scene_compositor(Scene * scene) Line 60	C++
 	blender.exe!DEG::DepsgraphNodeBuilder::build_scene_render(Scene * scene) Line 40	C++
 	blender.exe!DEG_graph_build_for_render_pipeline(Depsgraph * graph, Main * bmain, Scene * scene, ViewLayer * __formal) Line 303	C++
 	blender.exe!render_init_depsgraph(Render * re) Line 2092	C
 	blender.exe!RE_RenderFrame(Render * re, Main * bmain, Scene * scene, ViewLayer * single_layer, Object * camera_override, int frame, const bool write_still) Line 2121	C
 	blender.exe!render_startjob(void * rjv, short * stop, short * do_update, float * progress) Line 692	C
 	blender.exe!do_job_thread(void * job_v) Line 377	C
 	blender.exe!tslot_thread_start(void * tslot_p) Line 260	C
 	[External Code]
 	blender.exe!invoke_thread_procedure(unsigned int(*)(void *) procedure, void * const context) Line 92	C++
 	blender.exe!thread_start<unsigned int (__cdecl*)(void * __ptr64)>(void * const parameter) Line 115	C++
 	[External Code]
I have a similar problem where camera is parented to and empty which is parented to an object. See attached file, it crashes on render too:
Worked yesterday in a1ad71304c2d
@Marcin Twarowski (Tvaroog) Same error.
Crashes get_cow_id too. Again &object->id is NULL
