Added hotkeys to switch mode disfunctional / lost hotkeys in keymap #65064
8 Participants
Reference: blender/blender#65064
Broken: version: 2.80 (sub 69), branch: master (modified), commit date: 2019-05-19 04:56, hash:
f2eef45200
When i add hotkeys to the modes, then this hotkeys does simply nothing. I can't jump to edit mode with added hotkey alt 2 for example.
The second thing could be related, which i can't really test since the hotkeys are disfunctional anyways.
But when i add a hotkey to switch to pose mode, with a armature selected, and switch to a primitive then, and export the keymap, then the hotkey to switch to pose mode is destroyed in the exported keymap. The mode is missing. Vice versa too. When i export the keymap with the armature selected, then the modes for the mesh primitives, to switch to sculpt mode for example, are gone.
What is obvious in the keymap manager is, when i change the object type, then the mode button for not fitting modes turns blank. That's the hotkeys that are missing then after exporting the keymap ...
Open Blender. Add Hotkey Alt 2 for Edit Mode, Hotkey Alt 4 for Sculpt Mode with the cube selected. Then add Alt 3 for Pose Mode with a armature selected. Try to use the hotkeys.
Now export the keymap with the cube selected. And have a look at the code.
testkeymap.py
Added subscriber: @tiles
Added subscriber: @ZedDB
At least for the first issue, the problem is that alt + 2 is already bound to something in the default keymap.
Just search for the
alt + 2
in the keymap any the conflicting key maps will show.Is the second issue still happening for you?
Ah sorry for overlooking that i use a hotkey that is already in use. Yes, it still happens. It doesn't matter what hotkey i assign here. The problem isn't the double, it's that the hotkey gets lost when saving the keymap.
I can confirm that the
Mode
for the pose keymap vanishes when selecting an object that doesn't have a pose mode.Added subscriber: @ideasman42
Added subscriber: @XSI-Guy
I am having the same issue even now with Blender 2.9 released version.
Has there been any progress on this issue ?
Added subscriber: @dfelinto
Hi @XSI-Guy this was triaged as a known issue, which is a way to document the current limitations of a module.
Anyone is welcome to help tackling it, but the UI module has no plans of working on it in the foreseeable future.
Added subscriber: @alok1974
I am trying to take a stab at this. Please note that the solutions that I propose down here might not be the best as I have started on Blender and its source code just a week ago!
Problem
While exporting, the
keymap
datais read from the
userpref` UI, which in turn is dynamically updated depending on the context of the selected object's mode . Object modes are culled for a context and thus modes available in one object context (like 'POSE' in armature) might not be available on another object context (mesh cube). This leads to blank UI and consequently <''> in the exported key config.First Solution
draw_keymaps()
inrna_keymap_ui.py
with a modification to not draw box.template_keymap_item_properties(kmi). This keymap exports will be read from the internal memory correctly.Pros
Cons
Second Solution (Tested and I have the code almost ready)
str != ""
in this case).Pros
Cons
I am looking to fix this, let me know if and how can I proceed @dfelinto, @ideasman42
Cheers!
This issue was referenced by
919558854d
Thanks @ideasman42 !
I will learn a lot from the changes you made.
