Object mode switch seems to fail in script function but works directly in blender python console #65087
2 Participants
Reference: blender/blender#65087
Operating system: Windows 10
Graphics card:
Broken: (example: 2.79
Not sure if this qualifies as a bug or if I am simply misusing, however, the behaviour is unexpected. The following code when placed in a python script and imported into the blender python console fails to switch the object mode, however, works fine when manually entering each line of code into the blender python console or when creating the function below inside the blender python console and calling the function.
The lines which seem to fail.
bpy.ops.object.mode_set(mode='EDIT', toggle=False)
obj.scale = scale_factors
bpy.ops.object.mode_set(mode='OBJECT', toggle=False)
The actual python function being tested using params obj_name="Liver" and scale_factors = (0.5, 1.0, 1.0):
def scale_object(obj_name, scale_factors):
imported and called as:
import phantom as phtm
phtm.scale_object("Liver", (0.5, 1.0, 1.0))
The function scales the mesh properly but appears to be unable to switch the object mode from 'EDIT' back to 'OBJECT'. As I eluded to above, this code is not problematic when manually executed inside the blender python console.
Added subscriber: @bmoroz82
Added subscriber: @mont29
D
andC
are quick-access helpers featured by Blender python console, they are not available otherwise, you need to use explicitbpy.data
andbpy.context
instead.Please use https://devtalk.blender.org for such questions, this is a tracker for actual bugs. ;)
