Wireframe Shading in Edit Mode is a Semi Transparent White Since Yesterday's Shading Update. #65104
Reference: blender/blender#65104
Operating system: Windows 10 LTSC v1809 Build 17763.504
Graphics card: GTX 970 (418.81 WHQL)
Broken: blender-2.80, caf52e3779a9-win64
Wireframe Shading in Edit Mode is a Semi Transparent White/Grey Since Yesterday's Default Shading Update. (It used to be darker?)
It seems like some sort of a white overlay being drawn only when in Edit Mode? Because even with Solid/MatCap shading in Edit Mode. The surface looks brighter compared to Object Mode. Kind of like a Lighten/Screen Filter in Photoshop. Not sure if this was intended, but thought I'd report it cause it felt very distracting when using on a more complex mesh. Very bright and dithery compared to the darker, more transparent version before this change. :)
Thanks for all the hard work guys. Cheers.
(Attached Video)
20190525_EditMode_Wireframe.mp4
Opaque faces in wire also make more dense meshes much harder to see:
The increased alpha also causes issues with UV unwrapping since you can't see the underlying texture as well, comparison of 2.7x and 2.8x.
The opacity is so high that pure black in this example is closer to white then black.
The same mesh as wire.
Higher opacity makes face-dots harder to see, the white also looks like it could be a highlight when it's not.
Added subscriber: @JonDoe286
Added subscriber: @ideasman42
Caused by
203f9a49e2
Agree this isn't an improvement, it seems all tests were done with a fully shaded mesh, not wireframe.
Thanks for confirming Campbell. And also for the before and after comparisons. I didn't have a build from before to compare with. --- Agree, It makes it very distracting when working on dense meshes trying to select through.
PS: Hope the video played alright, cause on my end it played twice and now it says, "No video with supported format and MIME type found." I can re-attach if needed. Cheers.
Not sure if this is the actual cause/fix for it. But when you mentioned Alpha, made me think it might be related to theme settings. :)
Theme Settings > 3D View > Face seems to have an Alpha value of 0.129. Changing it to "0" seems to have done the trick.
This seems to have brought the old darker/transparent look back. But I've got no way to compare with an older build. Hope this helps. Cheers.
20190526_EditMode_Wireframe_Alpha.mp4
Wireframe (Object Mode) - Lines seem much clearer & contrasted.
Wireframe (Edit Mode) - Lines seem faint & noisy. Kinda like looking through a mesh filter. Not sure if its an Anti-Aliasing thing. AA is set to Default (8 Samples)
Cause I remember Edit Mode Wireframe used to be sharper? Even with new Edge Highlighting On, front facing edges are bolder, Yes. But occluded edges are quite faint.
Added subscriber: @WilliamReynish
Well the white face overlay is design to give more contrast and I can tell you that's what it does. But I agree opacity maybe a little too high when considering multiple layers.
I beg to differ. The right example is much more readable.
Yes. But this drawback can be counter workaround by disabling the edit face overlay in the overlay panel.
I agree we could lower the opacity of unselected faces. Maybe do something special for wireframe mode but I don't really like that idea.
@WilliamReynish do you have any opinion?
Thanks for clarifying Clément. When I look at it from that perspective, Sure. I can see it as a perk. Especially when using Edit Mode with Edge Highlighting = Off for better visual clarity in Vertex/Face select modes. Since the edges are much dimmer in those modes, the overlay does seem to help to still keep them visible and relevant without being lost in the dark grey of the viewport backdrop. Could definitely use some tweaking though. 0.129 value does seem a bit overpowering. :)
Also, that weird grainy/noisy "Overlay" look when in Wireframe mode was making the see-through aspect of it very distracting to read. Especially in denser meshes. --- Was wondering what caused it, so went on to try all different AA modes up to 32 samples with no change. --- Under viewport shading options, changed Xray value from 0.5 to 0.0 and voila. A nice clean, crisp and readable overlay appeared. :) Not sure why the Xray value was giving that noisy, sand-paper like look to the Wireframe Mode overlay. Or even if it was intended or not. But here's how it looks with both values. Hope it makes sense. :)
Wireframe Mode: Xray 0.5, Alpha: 0.129
Wireframe Mode: Xray 0.0, Alpha: 0.129
Wireframe Mode: Xray 0.0, Alpha: 0.071
Wireframe Mode: Xray 0.0, Alpha: 0.129, Value: 0.5 (Even tweaking the Value, we might be able to find a happy medium?)
Added subscriber: @MizManFryinPan
I apologize if this is a bit off topic but let me second Gibran when it comes to the grainy / noisy overlay. In wireframe + edit mode, I personally feel that it is very distracting especially when working with planes as images behind the model.
While the stippling of x-ray mode isn't a new issue, it's much more distracting/noisy with the newly increased alpha.
Anything against setting the x-ray alpha to zero?
The setting is separate from solid mode, where some alpha is necessary.
Oh, I wasn't aware that they are different between solid mode and wireframe mode. In that case, I support setting the wireframe mode's x-ray alpha to zero unless there is a better solution.
Ideally of course there would be a solution that keeps the softness gained from the alpha whilst removing the noise.
Though I guess most of this comes down to personal opinion so this is just my take on it.
Agreed. The grainy/noisy look of the Xray when in Wireframe wasn't really noticeable (didn't bother much) until the changes to the Alpha. I actually thought it was due to Anti-Aliasing. But later realized it was related to the Xray value in shading options. :)
In defense of the changes made to Alpha. I do get it. Especially with the new Edge Highlighting mode, it does help keep the mesh and edges stay visible and not get lost in the dark grey of the viewport background when in Vertex/Face select modes.
I'm cool with anything you guys decide as a default. As long as we have the option to set it to preference. Xray value and Face Alpha being those options. Thanks for all the hard work 'n have an awesome week guys! :)
We made the alpha lower and made the xray slider zero in wireframe mode.
Related commits:
8cfd46a5b0
5241dd1daf
Yeah, Noticed those on today's commit log. Thanks Clément. Appreciate it. :) Keep up the good work mate. Cheers.
