Eevee: ludicrous high value fireflys AO+Bent normals #65118
5 Participants
Reference: blender/blender#65118
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.80 (sub 72), branch: master, commit date: 2019-05-24 18:32, hash:
a629c74c9c
Seems that in that angle from the camera those objects align in order to generate the fire flies in the object "AA-Rojo_Interior" the SSS spread the firefly all around thats why i leave SSS to 1 in all the objects in the sample.
Turning off bent normals in the AO options or removing the normal map from the material "GrisPlastico" seems to "fix" or avoid the issue.
Firefly bug.blend
1-Switch to viewport render
2-scrub the timeline, around frames 220 - 230
Added subscriber: @NahuelBelich
Added subscriber: @moisessalvador
I can replicate it in the sense that they happened to me in some frames of an animation but I couldn't pinpoint what angles point of view caused it. All that I can confirm is that they happened with AO+Bent normal + Subsurface. It was force to fix this using the Compositor to clamp the high values, erase the alpha and use the Inpaint filter.
My system is Nvidia 1060 6gb, Windows 10 64bit
I cannot reproduce it here on my setup (linux + AMD Radeon Pro + mesa).
Maybe it's a driver bug on windows 7? Can anyone confirm that?
Added subscriber: @Jeroen-Bakker
We tried to reproduce this issue but were not able to.
Could you try to update your graphical drivers and test with the latest blender?
ok, ill try to test this further, ill try to do it as soon as i can
Ok i have done more tests.
in my main machine (i7 win7 gtx 1070 ), updated drivers (430) an last blender version and the bug its consistently appearing always there. 2019-06-04_23-49-56.mp4
Then i undust my old secondary machine a q9300, win7, nvidia 460 (updated drivers 354), and there the bug didn't appear. . . . nothing, works fine as it should.
So there is a problem i can see it in my main machine but i totally understand if this report its closed as "not enough info" or "not able to reproduce" since im with both machines same file in front of me, i can't get consistent behavior.
Ill keep an eye open in case i find any other clue to reproduce the error more consistently.
Can you pack the normal map inside the file?
DANG! ok im feeling really really stupid right now, i though i had paked, and i was sure when was moving a file that weight more than an 1mb with only that little mesh data. . . . anyways, ill test this again in my secondary machine later to check this version.
Its kind a bit big but this is the file with the normal map.
Firefly bug_packed.blend
This issue was referenced by
8fa65ed31b
I tested the fix with
8fa65ed31b
and8b2b79c210
and the viewport looks great and mainly worked but. .https://youtu.be/FUpuVy0LRTU
The problem seem to persist but in a different frame and a lot fewer, one more difficult thing its that its not possible or at least i wasn't able to reproduce with the demo .blend i uploaded later, so im going to disect the scene again to try to prepare another demo file to test it.
I was just commenting here to let you know.
By the way, what should i do if i can pin point a demo .blend reproduce the error? should i added here or create a new bug report?
Thanks
Changed status from 'Resolved' to: 'Open'
Yes just attach the blend file here.
Fireflybug_03.blend
In this file i got a consistent result
1 open
2 render
Changing anything makes the firefly don't appear.
For example:
Tested with builds
8b2b79c210
andaa003c7324
Unfortunately I cannot reproduce this time. I tried a blind guess and maybe it will fix the issue.
Hi, i have test with
4fb4415172
, rendered that problematic shot a few times with different sizes and also other cameras, that blind guess seems to be working i didn't see any fire fly, this scene shots are rendering properly now.Thanks
