Preferences: Keymap Preferences not visible afert importing custom key map #65121
15 Participants
Reference: blender/blender#65121
Graphics card: GeForce GTX 760/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.65
Broken: version: 2.80 (sub 72), branch: blender2.7, commit date: 2019-05-24 22:21, hash:
caf52e3779
Found this after I saved and imported my key map and then wanted to adjust mouse select button.
This is what I get.
This is what I get when I select the blender key map.
Added subscriber: @MichaelParucha
#91860 was marked as duplicate of this issue
#76028 was marked as duplicate of this issue
#75624 was marked as duplicate of this issue
#74132 was marked as duplicate of this issue
#73872 was marked as duplicate of this issue
Added subscriber: @brecht
This is by design, these preferences are only available for the default keymap. They can't be automatically applied to any keymap.
@brecht This means that when set those are exported too? Or how can they be changed then in the saved custom settings if needed?
Yes, the preferences are baked into the exported keymap.
Hmm, if I change the default "Select With" to right and export the key map its empty. So where are thos settings?
test-export.py
Added subscribers: @WilliamReynish, @ideasman42
@brecht One of the use cases for exporting the key map would be to install it on a second pc. So to do that I need to set the preferences in the Blender key map and save them and then import the custom key map, correct?
That does seem like a bug. If you export with all keymaps the changes should be included.
In general for sharing preferences between computers it's more reliable to share a userpref.blend, the way keymap import/export works now is really geared towards fully custom keymaps, not so much a few smaller tweaks.
Added subscriber: @zgorg
thks for the answer. very high priority for me. because of add-ons for instance. I did a ctrl tab under my own settings and was not working under 2.8 keymap. then I remember this problem of default interface on 2.8 not appearing on other keymaps. imagine a non confirmed user dealing with this. a nightmare. more when adding new keys in 2.8 like new outliner shortcuts they are not added to other shortcut keypmaps. imagine the deal to check every new changes by hand. example in text editor the new add comment toggle. this is an absolute priority in fact when dealing with millions of users and 2.8 shortcuts are far to be logical even for new users. but this is my own opinion
for information if keymaps are changed in Blender saving preferences won't save the previous state for your keys. like I'm explaining it there and the answer sound well there is no way to record your own keys.
Closing as this is working as intended.
Supporting preferences on saved keymaps is a non-trivial task.
Added subscribers: @RUben, @jenkm
Added subscriber: @borschberry
For example, I have a very complicated set of hotkeys that I transfer from version to version. Now, do I need to transfer it manually?
It seems to me that new hotkeys should be assigned default values, they should not disappear.
It's just a shame guys. Close the bug report because the bug is difficult to fix?
Added subscriber: @DanielGrauer
Added subscriber: @RomboutVersluijs
I wonder why this preferences isnt added, i read this is by design. But if one uses a keymap and uses that same keymap on a different system. He can never change the preferences part which shows at the top.
As a test i tried adding back that preferences part in a custom keymap and it works fine then. Atleasy i thought, i noticed that i missed the load function. I come back to that in last part here after editing it a bit more
The things like orbit and right- or left-click select are not shown anymore and cant not be saved, as far as i know the keymap. I still believe this is a bug, because a keymap doesnt behave the same. Now its set is set and you can never change it again, that doesnt feel right. The issue now is once you have a keymap setup, you can never change it again. Unless you run a find/replace in that py file ofcourse. Im not sure much users will come to that idea though. Wouldnt it be better to separate that main part into its own small operator. So it will always be visible and thus custom hotkeys can always be adjusted concerning the main navigation items.
EDIT
I did a test by adjust IO.py took me a while to get it working and i did need to hardcode blender app path. But now each preset i save can still be adjusted after wards. I basically keep that preferences part and loads the blender_default.py
So far my tests didnt show issues. The only thing though on initial load, it shows LEFT click for selection since that is the default in the blender.py file. I could make find the first mouse click in the shortcuts and use that as default.
io.py
closed because its a non trivial task? please explain how that solves the issue
It doesn't solve the issue, but it means it's not considered a bug and should not be in our bug tracker, it's a feature request.
@RomboutVersluijs, you might be able to make those buttons appear, but I doubt they actually work?
I tried it and it does work. Though i believe i need to run them again to make them actually change all buttons. Ive tried adding the add set up so they are read when keymap is read back in and don't reset to defaults. I find my method works better then current behavior because i cant change anything. Now i can change it afterward :)
The only thing which I'm still working on is making a custom blender_default.py because currently my io.py gets all defaults as well. It should only take the changed ones, I'm not 100% sure of that though. But the thing is if you change the keymap, then all keys need to be changed i believe. So perhaps my setup is the proper method after all. The keymap get twice as big now because it contains 16k of line in shortcuts ... oopss But i am able to keep switching now and don't need to start all over again. This is how it currently works, once you've set those preferences at the top, there is no way (like a normal way) to change it again.
PS can i as how i can reach the default preset folder within the app on OSX? Now I've hardcoded the path but i want to share it, it will not work. See #157 & #158
Ive added my change io.py file with how i add bak those key inputs in a keymap file
io.py
Added subscribers: @roberto.loriga, @TheRedWaxPolice
Removed subscriber: @jenkm
Added subscriber: @JoelArt
How do I use the io.py script?
BTW, I've suffered a lot due to this IDIOTIC design, how can the prefs not be available for all keymaps. If you've set left click as default then you are stuck with it for ever on your new keymap. How do I even make backups of my default keymap without losing the preferences when loading them back in again.
@JoelArt
Hi Joel, i havent tested it yet in newer versions though. I replace the file located in this folder
Fill XX with personal and bl version
Be sure to either move that old file or rename it just in case it does break something also test it properly. I ran it a couple times and didnt see weird behavior, though i didnt check all shortcuts ofcourse. I randomly tried as many as i could and they seemed to work. I also check one of the old keymaps stored in the user-folder.
You could also try opening one of the personal keymaps in a code-editor which allows you to compare them. Then see if they are different, you would do this by first saving a keymap without this new io.py, so save say "keymap-A" then replace (keep the old one!!!!) the io.py and name this "keymap-B" then compared them. The new version should have added code which i show below with the lien numbers.
I just check the io.py in 2.91 and they have added some lines to io.py, it now sorts the keymaps when storing, allows for easier comparing.
Another method is by adding the top part in case you want to edit it, but you would need to do that every time, then reload Blender. I think this is to tedious to do, the thing is each time you press something in the at top part, it loads and adjust all shortcuts on the fly. I cant remember how i did that part. I just looked at their base preset and it would take quite some time for me to figure it out again.
What you would need to is is copy/paste # 157, the part which says ''fw("import os\n.....``` and then lots code between the double quotation marks. You also need to add #206 to #231 and replace that with #212.
I added the adjusted version here below, i wasnt sure you would be able to do it yourself.
Again, make a backup or rename that io.py before you do this, otherwise you could break the ability to properly save keymaps in the future
@RomboutVersluijs Versluijs (rombout) Thank you!
Added subscriber: @Vyach
More like upgrading current behavior to full version.
But you are right, it is not for bugtracker. And it is weird, that there is no such request on RCS
Added subscribers: @costa, @PratikPB2123, @Xorrito
This exact problem just happened to me as I imported my shortcuts from Blender 3.3.1 to 3.5
The same thing happened in 3.3.1 since I exported.
I don't understand. Where can I report this as a bug and how can I fix this behaviour?
Any news or updates on this?
Can we reopen this issue. Even if this is considered a feature request it behaves like a bug from a user perspective.
For user feedback and feature requests, please use other channels: https://developer.blender.org/docs/handbook/communication/user_feedback/
