Keymap conflict (Node Editor / Node Wrangler) #65202
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
8 Participants
Reference: blender/blender-addons#65202
Graphics card: GeForce GTX 980/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.71
Broken: version: 2.80 (sub 72), branch: blender2.7, commit date: 2019-05-26 22:34, hash:
blender/blender@d525c76003
With the default keymap, Shift+RMB and drag on a connection on the Node Editor creates a reroute node, and Ctrl+RMB drag cuts the connections... but if Node Wrangler addon is enabled, Ctrl+RMB drag enables the "Lazy connect" option of Node Wrangler, overwriting the connection cutting shortcut. I understand that it's an addon, but being that it comes bundled in Blender and given that it's arguably necessary to get the most out of the Node Editor, it shouldn't create conflicts like this.
Works in any file. Just try to cut connections between nodes using Ctrl+RMB drag with Node Wrangler addon enabled.
Thanks!
Added subscriber: @OliverVillar
#66700 was marked as duplicate of this issue
blender/blender#66341 was marked as duplicate of this issue
Added subscribers: @WilliamReynish, @lichtwerk
@WilliamReynish : I am a bit on shaky ground when it comes to keymap convention: why are we having reroute/cut swapped from LMB to RMB (when choosing
Select with
Left
in keymap preferences)?in 2.79 it was always LMB (no matter what was chosen for
Select with
...)Just asking here to see if NodeWrangler should also do some keymap swapping [LMB <-> RMB] depending on
Select with
User Preference.@lichtwerk Well, Ctrl-LMB and Shift-LMB are use to add and remove for box select, so they are already used. Same in other editors, which is why setting the 3D Cursor in the 3D view is done with Shift-RMB.
Added subscriber: @BrendonMurphy
hi, with addons overwriting built in key maps usually they provide same functionality, extended functionality or pie v's standard menu. They should where possible not overwrite built in functions. The simple solution in this case would be to remap the offending keymap conflict/s in the addon.
@lichtwerk as the default is now left click select, it's all that's required by the addon. To work with the defaults. That said, if there was a module that addons could call that generically swaps "left to right" it would be handy for old timers that still wish to use right mouse select?
@WilliamReynish : ok, I see (sort of -- I am RMB selector....we dont have LMB box in the node editor... except for the box-tool, then reroute/cut is not functional which is expected...)
having this swapping generic would be nice. for this report: should we just go over shortcuts and swap depending on preference?
Yes that should work. Maybe the offending key could be moved to alt shift?
Added subscriber: @AlexBitsadze
Added subscriber: @billyand
Is this supposed to be assigned to someone or is this just not that much of a problem?
hi, assigned to Philipp, We all know about this issue.
Changing priority to high. We need to make a decision and make a move on this before rc1.
Hesitating to just commit something here, but here is what I would do:
Default keymap current state
Alt
RMB
freeCtrl
RMB
cut linksCtrl
Shift
RMB
freeNodeWrangler current state
Alt
RMB
Lazy mixCtrl
RMB
Lazy Connect (offending)Ctrl
Shift
RMB
Lazy Connect menuNodeWrangler proposed future
Alt
RMB
Lazy ConnectAlt
Shift
RMB
Lazy Connect menuCtrl
Shift
RMB
Lazy mixThis keeps the two
Lazy Connect
on a common "base" key and movesLazy mix
... Does this sound OK?Added subscriber: @brecht
Sounds good to me.
Seems reasonable
Added subscriber: @SeanKennedy
Is there a way for cut links to go back to ctrl LMB? Right now LMB and Ctrl LMB both do box select
@billyand : LMB is select [Deselect on nothing ON], Ctrl LMB is select [Deselect on nothing OFF] (which is like toggle), so these are not the same...
Guess I will commit the above now...
This issue was referenced by
e08d6983c0
Added subscriber: @Damjan-2
