Array modifier shows wrong array number of objects in edit mode of linked objects
Open, Confirmed, LowPublic
Operating system: windows10
Graphics card: NVidia GeForce GTS 250
Broken: 2.80 Beta 2019-05-29 18:17, hash: fee600f47980, branch: blender2.7
When I select a Window object (which is duplicated linked [alt+d]) which has array modifiers and change to Edit Mode another linked window (alt+d'ed object) shows current selected modifier on all of them.
Open Blender with default layout and add an object then duplicate it (using alt+d). On two objects give them different Array modifiers and then toggle between them in edit mode.
In attached file just toggle between Cube and Cube.001 and go into Edit Mode on first and on second separately.
Blend file:
Daniel Bystedt (dbystedt) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.May 31 2019, 12:33 AM
I get the same results
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.67
Broken: version: 2.80 (sub 73), branch: blender2.7, commit date: 2019-05-30 17:34, hash: rB846056de6b27
Brecht Van Lommel (brecht) raised the priority of this task from Confirmed, Medium to Needs Triage by Developer.May 31 2019, 12:54 AM
Norbert Kowalczyk (TherockyDoo) renamed this task from [possibly a bug] Array modifier shows wrong array number of objects in edit mode of linked objects to Array modifier shows wrong array number of objects in edit mode of linked objects.May 31 2019, 9:46 PM
Brecht Van Lommel (brecht) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.
This kind of linked duplicate display in edit mode is only used for objects without modifiers in 2.7. We could do the same in 2.8.
I looked into this issue.
We could limit the duplicate display in edit mode for this specific case, but it won't solve the rendering issue. It might be related to the draw manager cache. The reason could be that the edit_mash has more precedence then the object mesh so rendering will be done by default in the edit mesh mode, what has the modifiers applied of the active object. making all linked duplicates render in the same way, eg with the wrong modifiers.
It could be that this can be steered from the depsgraph, need to look more into this.
Brecht Van Lommel (brecht) lowered the priority of this task from Confirmed, Medium to Confirmed, Low.Jul 3 2019, 6:24 PM
