Crashes on first click on model #65420
5 Participants
Reference: blender/blender#65420
Broken: 2019-06-01 22:51
079c7f918c
C.view_layer.objects.active = D.objects['Camera']
Simplified file (just open and select the cube):
crash-on-select-simple.blend
Original Report
K8_LOD0.blend
Click on arm. blender crashes to desktop.
Added subscriber: @OXO
Added subscriber: @matc
Crash happens in
stats_object_edit(Object *obedit, SceneStats *stats)
whereBKE_editmesh_from_object(obedit)
returns NULL. Selecting "StickHandRD" in the Outliner has the same effect.Selecting another Object ("SickLU") and switching to edit mode causes a crash in
undomesh_from_editmesh
where the edit mesh is NULL for "StickHandRD".From the Data API it looks like "StickHandRD" is already in edit mode, without being selected. This is the only difference between "StickHandRD" and "StickHandLD" that I was able to spot (both have the same number of vertices etc.).
K8_LOD0.blend
I should like to escalate this one because its preventing me from continuing with testing 2.8
Added subscriber: @brecht
We define the priority.
@matc normally when we developers set a bug to confirm, it should be assigned to a developer immediately. Otherwise it's looks as if it's been triaged but none of the developers have assessed what kind of priority it has and who should look into it. If you don't know who to assign it to, just leave as Needs Triage.
This may be related to #62450 (Undo crash after hiding object in edit mode) in some way.
The issue on stat info, looking into it.
//source/blender/editors/space_info/info_stats.c:212:25: runtime error: member access within null pointer of type 'struct BMEditMesh'
Full backtrace: P999
Added subscribers: @ideasman42, @dfelinto
@OXO do you have instructions on how to reproduce this from scratch? Or any clues on which steps you did, what you were trying?
The issue here is that after selecting the object it becomes active, but for some reason the object is in edit mode ((ob)->mode & OB_MODE_EDIT) yet BKE_editmesh_from_object( ) returns NULL.
@ideasman42 you may want to take a look at this?
And even if we were to ignore this will break later down the line for the same reason.
And for the records, it was not introduced on
db67a17d17
.And slightly simplified file:
crash-select.blend
(removed the other objects and the other view layers)
I can't say what caused this. The model was originally a wings3d file, which was imported to blender via wavefront obj import.
Then later another obj import with the offending Arm part was done.
I then worked on the modelling for some days, and out of the blue after duplicating the arm, it showed this issue.
Alright, managed to reproduce from scratch:
The issue is that ED_editors_init() doesn't initialize the object, nor clear its ob->mode flag (to remove OB_MODE_EDIT).
This issue was referenced by
6a15564682
I think https://wiki.blender.org/wiki/Process/Help_Triaging_Bugs should be more clear about that.
Thanks for pointing that out, I've updated the page now.
