.bphys cache never writes particle size #65467
2 Participants
Reference: blender/blender#65467
Operating system:Windows
Graphics card:gtx660
Broken: 2.79 probably 2.8 too.
When reviewing the resulting .bphys cache files, the only thing written to the cache file is LOC and VEL.
Bake the cache on the supplied BLEND file which will generate one particle.
Run the supplied python program to view the resulting one particle one frame cache.
There are only two pieces of data stored for the Newtonian particle, location and velocity.
Line #289 here:
https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/pointcache.c
Shows the data type being assigned &pa->size could this be the problem? Does it need to be pa->size (remove the ampersand?)
27_make_one_particle.blend
Added subscriber: @AtomP
Added subscriber: @brecht
It's true that the size is not written,
BKE_ptcache_id_from_particles
determines which data will be written. But have you found that this leads to a bug in Blender, does the size need to be written to correctly reconstruct the particles state? The existence of unused code by itself does not mean there is a bug.Size is also not read from the external .bphys file. So if I decide to write an external python script to generate a .bphys file,blender ignores the supplied size information. This does seem to be a bug.
Shouldn't Blender reliably relay the size information in the type def, if it is supplied by an external file?
While this would be useful, that's beyond a bugfix. The file format is defined by what it actually writes, not what disabled code could do. Even then this is an internal file format, not strictly defined by any specification.
The size is not something that is simulated, it is computed on the fly based on some settings. Changing that in the current particle code is messy, it's more likely to happen when we rewrite the particle system.
