Point Density causes Crash
Closed, DuplicatePublic
Operating system: Windows 10, 64 bit, Version 10.0.17134 Build 17134
Graphics card: 4x Radeon VII, Driver Version 19.5.2
Processor: Threadripper 2990WX 32-Core on X399 Chipset (Gigabyte Designare Motherboard rev 1.0)
RAM: G.Skill Snyper 64GB (4x 16GB), 3200MhZ
Broken: 2.80, c13e10a7404d
Worked: Don't know, it's the first time I try using Point density in Blender 2.8
When Cycles Viewport preview is active, Blender tends to crash whenever I change settings in the Point Density Node.
  • Make Start-Cube a Volume Scatter Material, don't plug anything into the Surface Output
  • Add Sphere, scale it down a bit
  • Add Point density node in the Cubes material and set it to Object Vertices
  • Set Sphere as Target Object in the point density node
  • Activate rendered preview with Cycles engine
  • Play around with the settings in the Point Density node, it won't take long until Blender crashes
Jacques Lucke (JacquesLucke) triaged this task as Confirmed, Medium priority.
Simplified Stacktrace:
rna_Node_refine(struct PointerRNA * ptr) (/home/jacques/blender-git/blender/source/blender/makesrna/intern/rna_nodetree.c:1185)
RNA_pointer_create(ID * id, StructRNA * type, void * data, PointerRNA * r_ptr) (/home/jacques/blender-git/blender/source/blender/makesrna/intern/rna_access.c:168)
ccl::BlenderSession::builtin_image_float_pixels(ccl::BlenderSession * const this, const std::__cxx11::string & builtin_name, void * builtin_data, float * pixels, const size_t pixels_size, const bool free_cache) (/home/jacques/blender-git/blender/intern/cycles/blender/blender_session.cpp:1431)
ccl::ImageManager::file_load_image<(OpenImageIO_v1_8::TypeDesc::BASETYPE)11, float, ccl::float4>(ccl::ImageManager * const this, ccl::ImageManager::Image * img, ccl::ImageDataType type, int texture_limit, ccl::device_vector<ccl::float4> & tex_img) (/home/jacques/blender-git/blender/intern/cycles/render/image.cpp:631)
ccl::ImageManager::device_load_image(ccl::ImageManager * const this, ccl::Device * device, ccl::Scene * scene, ccl::ImageDataType type, int slot, ccl::Progress * progress) (/home/jacques/blender-git/blender/intern/cycles/render/image.cpp:807)
ccl::TaskScheduler::thread_run(int thread_id) (/home/jacques/blender-git/blender/intern/cycles/util/util_task.cpp:396)
ccl::thread::run(void * arg) (/home/jacques/blender-git/blender/intern/cycles/util/util_thread.cpp:52)
start_thread(void * arg) (/build/glibc-OTsEL5/glibc-2.27/nptl/pthread_create.c:463)
clone() (/build/glibc-OTsEL5/glibc-2.27/sysdeps/unix/sysv/linux/x86_64/clone.S:95)
Slightly simplified reproduction steps:
  1. Open the file.
  2. Enable cycles viewport rendering.
  3. Change the settings in the Point Density node until Blender crashes.
I was able to reproduce all three times I tried.
Same underlying issue as the smoke one, point density is just another volume synced to Cycles.
