Driver not interpreted correctly during (eevee) render #65570
Closed
opened 2019-06-06 16:54:28 +02:00 by Adrian Röfer · 6 comments
Operating system: Windows 10
Graphics card: Nvidia 1060 GTX
Broken: (example: 2.80, 8b2b79c210, branch: blender2.7, 2019-06-06, as found in system-info.txt)
I set up a driver driving an object's z-position based on its z-rotation to animate a nut. The animation looks fine when played back in the viewport, but only jumps when rendered out.
This video demonstrates the problem: https://youtu.be/P2RY9pAJOFA
File is attached and the correct scene is opened. Just look at the animation in viewport and then render it and play back the render.
.blend file showing the issue: kinematics.blend
**System Information** Operating system: Windows 10 Graphics card: Nvidia 1060 GTX **Blender Version** Broken: (example: 2.80, 8b2b79c2108b, branch: blender2.7, 2019-06-06, as found in system-info.txt) **Short description of error** I set up a driver driving an object's z-position based on its z-rotation to animate a nut. The animation looks fine when played back in the viewport, but only jumps when rendered out. This video demonstrates the problem: [[ https://youtu.be/P2RY9pAJOFA ]] **Exact steps for others to reproduce the error** File is attached and the correct scene is opened. Just look at the animation in viewport and then render it and play back the render. .blend file showing the issue: [kinematics.blend](https://archive.blender.org/developer/F7090254/kinematics.blend)
Author
Added subscriber: @aroefer
Member
Sergey Sharybin was assigned by Jacques Lucke 2019-06-07 14:34:47 +02:00
Member
It feels like a dependency cycle or so in the file. Just going back and forth in time, changes where the object is in the same frame.
However, no dependency cycle is reported, so it's probably something else..
@aroefer, can you remove everything from the file, that is not necesssary to reproduce the bug?
It feels like a dependency cycle or so in the file. Just going back and forth in time, changes where the object is in the same frame. However, no dependency cycle is reported, so it's probably something else.. @aroefer, can you remove everything from the file, that is not necesssary to reproduce the bug?
Author
@JacquesLucke of course! I've removed all unnecessary scenes and objects. The bug sadly persists. This is the new file: kinematics_minimal.blend
@JacquesLucke of course! I've removed all unnecessary scenes and objects. The bug sadly persists. This is the new file: [kinematics_minimal.blend](https://archive.blender.org/developer/F7091944/kinematics_minimal.blend)
This is caused by attempts to drive object's location from a final object rotation. This can not be supported because final transform is evaluated as a transformation matrix and can not be decoupled.
The dependency cycle is not reported because of workaround-type commit done to make #52255 to work.
ideally we should allow referencing RNA properties directly, which makes this issue solvable in theory. But with current state we'll hit #64793.
For now the only solution is to re-rig the scene so it doesn't need to address self's transformation in transformation channels.
Here is a very simple scene, where Z location is driven by Z rotation.
Note that this issue persisted in 2.79 as well.
z_loc_from_z_rot.blend
This is caused by attempts to drive object's location from a final object rotation. This can not be supported because final transform is evaluated as a transformation matrix and can not be decoupled. The dependency cycle is not reported because of workaround-type commit done to make #52255 to work. ideally we should allow referencing RNA properties directly, which makes this issue solvable in theory. But with current state we'll hit #64793. For now the only solution is to re-rig the scene so it doesn't need to address self's transformation in transformation channels. Here is a very simple scene, where Z location is driven by Z rotation. Note that this issue persisted in 2.79 as well. [z_loc_from_z_rot.blend](https://archive.blender.org/developer/F7091874/z_loc_from_z_rot.blend)
Closed as duplicate of #64793
Reference: blender/blender#65570
