Copy Attributes copy visual transformation (e.g. location/rotation) problem with Child Of constraint
Open, Needs Triage by DeveloperPublic
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.67
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-06 00:27, hash: rB8b2b79c2108b
Exact same problem as T53361. Creating a new bug report per suggestion, but may want to follow the discussion on the task.
Original writeup:
I'm trying to use the "Copy Visual Location" and "Copy Visual Rotation" functions from the Copy Attributes addon to get around a problem in rigging a character.
(BlenderArtists post: https://blenderartists.org/forum/showthread.php?440992-IK-FK-setup-Bone-position-changes-when-dialing-between-Child-Of-constraints)
Normally, copying visual transformation works perfectly fine. But when the bone having the visual transformation applied to has a Child Of constraint, the result is always offset. Demo:
Example file attached.
To see the problem, you can download the .blend file and copy the steps as in the animated .gif. Here're written steps if needed:
  1. Enable the "Copy Attributes" addon.
  2. Create a bone (Bone A, let's say) with a Child Of constraint to another bone (Bone B).
  3. Move Bone B.
  4. Create another bone (Bone C).
  5. Select Bone A (The one with the Child Of constraint), then shift select Bone C.
  6. Press [Ctrl]+[c] to bring up the Copy Attributes menu.
  7. Select a visual transformation (e.g. "Copy Visual Location")
You'll see that it doesn't do the expected behavior (snapping Bone A to exact location of Bone C), but is offset due to the Child Of constraint.
