Crash when using "Render Viewport Animation" #65601
2 Participants
Reference: blender/blender#65601
Operating system: Windows 10 Pro 64
Graphics cards tested: GeForce GTX 10180 Ti, AMD Ryzen 5 CPU with Vega 11
Broken: 2.80-749d53effd58-win64
Worked: 2.79
Blender interrupts "Viewport Render Animation" and crashes after an amount of frames, depending of the used graphic card.
I've tested it on my workstation with a GeForce GTX 1080 Ti and on another PC with a AMD Ryzen 5 2400G with a Vega 11 OnBoard graphics unit.
On my GeForce the viewport rendering crashes at around 800 frames. On the AMD CPU it crashes after around 300 frames. So I presume it's because of the graphic card memory.
The whole animation is rendered fine by using the viewport rendering in Blender 2.79.
Because my animation is under NDA I can't publish it here. I've tried to create a similar, neutral scene with some cubes and equal animation options. But the animation rendered without any problems.
Before I start to reduce the complex scene for debugging it in Blender 2.8 (It has hundreds of objects), first my question:
Is there a log file that will be saved after a Blender 2.8 crash? If so, where I can find it?
I would publish it to you here. Maybe it helps to investigate the problem?
Thank you
Chris
Added subscriber: @ChristophWerner
Update:
Today I've installed version: blender-2.80-a0608340ae14-win64.
After a new test all seems to work fine. Please close my post for now.
Thank you
Chris
