glTF 2.0 exporter exports previously deleted objects
Operating system: Windows 7, 64 bit
Graphics card: Nvidia GeForce GTX 760
Broken: 2.80: 2019-06-08 13:24 (81b68f7279cd) --> self compiled
Blender seems to cache deleted objects under some circumstances. If a mesh is exported to glTF 2.0 where another mesh was attached hierarchically. This deleted mesh is exported to the glTF file.
  1. Open Blender and load the attached demo file
  2. Delete the object (mesh) "sub-object" which is attached to "top-object"
  3. Select: File -> Export -> glTF 2.0 (.glb/.gltf)
  4. Export the file (default settings)
  5. Open a new Blender instance
  6. Select File -> Import -> glTF 2.0 (.glb/.gltf)
  7. Import the previously exported glTF file
  8. The deleted object "sub-object" is here again
Demo file
Logs
The Export logs of the glTF exporter reports:
'[BLENDER-BIN-FOLDER]2.80\python\lib\site-packages\extern_draco.dll' exists, draco mesh compression is available
20:58:55 | INFO: Starting glTF 2.0 export
20:58:55 | INFO: Extracting primitive: sub-mesh --> This should not be here
20:58:55 | DEBUG: Adding primitive without splitting. Indices: 6 Vertices: 4
20:58:55 | INFO: Primitives created: 1
20:58:55 | INFO: Extracting primitive: top-mesh
20:58:55 | DEBUG: Adding primitive without splitting. Indices: 36 Vertices: 24
20:58:55 | INFO: Finished glTF 2.0 export in 0.014001607894897461 s
Hello,
Note that discussion will take place in upstream repository bug tracker : https://github.com/KhronosGroup/glTF-Blender-IO/issues/537
Julien DUROURE (julien) closed this task as Resolved.Sun, Jun 23, 10:02 AM
