Regression? Convert curve with bevel into mesh does not create the expected geometry
Closed, DuplicatePublic
Operating system: openSUSE Leap 15.1 kernel 4.12.14-lp151.28.4-default
Graphics card: NVIDIA GTX970 openGL 4.6.0 driver 430.14
Broken: blender-2.80-749d53effd58-linux-glibc224-x86_64
Trying to convert into mesh a beveled bezier circle (using a bezier curve) results in a circle mesh (2d) and not in a 3d geometry.
It seems to be a regression because I remeber to have used this feature in past 2.8 builds.
  1. Create a bezier curve
  2. Create a bezier circle
  3. Edit circle geometry referencing the bezier curve in the bevel selection, the circle now assumes a 3d look
  4. Convert the circle into a mesh, the generated mesh is a 2d circle instead of a 3d geometry
I don't know how to provide an attachment, in case, here it is the OneDrive link of a sample blend file: https://1drv.ms/u/s!Av-7LEq1D6es21LuAAWSVEWvhzQ7?e=tCzeGD
works for me, same blender version.
Operating system: Linux-4.15.0-48-generic-x86_64-with-debian-stretch-sid 64 Bits,
Bastien Montagne (mont29) triaged this task as Needs Information from User priority.
Cannot reproduce either, are you sure you are suing latest build?
To attach a file, just drag'n'drop it in a text edit field…
That one actually looks a lot like T65295, are you using the 'keep original' option of the convert operator?
I have this issue in both cases; when I use the "keep original" option, next similar operations do not show the operation panel
I cannot reproduce the issue when 'keep original' is not enabled…
I'm sorry: I confirm the issue happens only when keep original is checked, hence I suppose it is a duplicated entry
