Driver Referencing A Custom Property In Light Object Data Does Not Get Updated On Change
Operating system: Windows 10 64 bit
Graphics card: Nvidia GTX 750 Ti
Broken: blender-2.80.0-git.81b68f7279cd-windows64
When a driver references a Single Property that is stored inside a light's object data, the driver's value is not updated when the property is changed.
(If the property is keyframed, however, it works. It also works for rendering.)
Scene Description:
The light on the left (Light.Object) has its power controlled by a driver reading from a custom property (OnObject) in the object itself.
The light on the right (Light.Data) has its power controlled by a driver reading from a custom property (OnData) in the light's object data.
Steps:
  1. Set the viewport to "Rendered".
  2. Change the value of the property OnObject in Light.Object. The (green) light correctly turns on / off.
  3. Change the value of the property OnData in Light.Data's object data. The (red) light does not respond. I'd expect it to update when the value changes.
