Graph editor, curves messed around if more than one bone selected
Needs Information from User, NormalPublic
Graphics card: GeForce GTX 960/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 398.11
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-11 23:43, hash: rB6529d20d79a5
Hello!
I think i found a quite anoying bug for animators, if you select two bones, with individual origins and move them with gymbal orientation on a single axis, when you go to the curves, you can check that all the three axis (Z,X,Y) are moved around. Only one should be moved since you're using individual origins + gymbal orientation.
  • I tested the problem in different computers, with different versions of 2.8 using Spring rig and using Boris rig in 2.79 and 2.8. In all of them the problem occurs
  • Open blender 2.8 with spring rig (for example)
  • Divide the screen in two parts, one with the viewport view and the other one with the graph editor
  • Select both eyebrow general controllers
  • Put the pivot point in Individual origins
  • Use gymbal orientation
  • Move both eyebrows in Z location (check that it sais "along gymbal Z)
  • Check the graph editor, you'll see that at least two axis are moved around.
    OBSERVATION: sometimes it DOESN'T happen, but if you do it several times, at some point it happens (just do it fast 5-6 times and it should happen)
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Jun 17 2019, 4:37 PM
Can you attach a minimal example file?
Quoted Text
Yes, of course! https://imgur.com/a/KVapWs7 here you have the images with step by step. Maybe it's normal but I think it should just move around one axis, am I wrong? Anyway, if you know how can i attach the .blend file I'll upload it.
If you click on the "cloud" icon just about the comment input field, you will get a file dialog that you can use to upload the .blend file.
I think i've done it alright, but im not sure
Sebastian Parborg (zeddb) raised the priority of this task from 30 to 50.
@campbell any input on this? It seems to work better when using local transformation mode.
Sybren A. Stüvel (sybren) changed the task status from Confirmed to Needs Information from User.Tue, Feb 11, 12:13 PM
@Josep (Velorth) please give us a minimal example file, this file is far too big to dive into.
