Sequencer OpenGL Render : Annotations not rendered with python command but is rendered using UI button #65763
Reference: blender/blender#65763
Operating system: Windows-10-10.0.16299 64 Bits
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.65
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-11 23:43, hash:
6529d20d79
Sequencer OpenGL render using python command doesn't export Annotations but clicking on the View -> Sequence Render Animation does export Annotations.
Added subscriber: @Miadim
Added subscriber: @Jeroen-Bakker
When clicking on
the area has a setting if the annotations needs to be exportedThe python API does not have a setting to render annotations and cannot get to the context of the sequencer. You might have zero or multiple sequencer areas open. By default it does not export annotations as it is not expected to do so.
Thank you for answering.
I'm not sure to get what you're talking about. This worked for me few days ago... And it still works on an older code on Blender 2.77. I changed things in the current code, but I can't figure out what I might have done wrong on what you're saying.
I've tested le context I'm currently in before calling this operator, and it's a 'SEQUENCE_EDITOR'.
Hi @Miadim
Hmmm... I will perform a bisect tomorrow to find out when the different behavior started. I did several fixes in this area. There might be some conflict going on.
Please note that the 2.77 Grease Pencil/Annotation system has been spliced in 2.80 into a Grease Pencil, what will always be rendered and an annotation system. Not sure the real thoughts are behind the annotations in conjunction with the opengl rendering.
Ah, then the script in the
.blend
file might not be complete as it perform in a different context. So you have an operation that executes the opengl render in the sequencer context, and there you expect the annotations to be present.I tried versions upto 1 month ago and was not able to find a version of blender 2.80 that exported the annotations as you describe it would with your given example file. In Blender 2.79 when running the same script as provided in your blend file, it also does not export the grease pencil layers.
When the next script is called from a sequence editor area it uses the settings of the area and the annotations are exported in 2.79 but not in 2.80. Is this what you are referring to?
Note: when rendering stills it is working. When rendering animations the first frame is correct, but the second frame is shifted by half width and height. So the third frame will move the annotation outside the export canvas.
This issue was referenced by
31a99a3ab4
Hi, I was trying to build an older version of blender to find how I managed to make it work few days ago, but it seems you handled it. Is it working now ?
