linked duplicate objects - issues with selection in edit mode #65778
8 Participants
Reference: blender/blender#65778
Operating system: Windows-10-10.0.16299 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.67
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-12 18:00, hash:
2404220e80
linked_duplicate_selection_bug.blend
There are problems with selection when you edit two objects at the same time in edit mode: the original object and a linked duplicate. See the video:
Desktop 2019.06.13 - 10.51.57.01.avi
Added subscriber: @MarcinTwarowski
Added subscriber: @tomjk
I see two things here:
You want to edit the two linked objects at the same time, but you can only edit one the active one.
I don't think this rises to the level of a bug, but a feature request. Ideally you could select any element from the inactive object and it would instantly become the active object.
(It might also be nice to be able to work on any feature from both object, but I think the ability to perform operations such as rotate and scale on selections across multiple instances of the same mesh at the same time might introduce complexity.)
The selection display falls out of sync between instances until you perform an operation.
I can confirm this. It happens either if you have one or multiple instances selected, all other instances enter edit mode then don't sync selections properly.
I really only meant that selections don't sync properly.
Ah, ok then. Yep that's a bug.
Added subscribers: @fclem, @ideasman42, @brecht, @dfelinto
I can confirm this bug, but there are two scenarios:
In this case I think we shouldn't draw the "edit mode engine" layer for the dupli objects. So the bug reported here won't even be a problem.
In this case, in the ideal world, we should be able to select, snap, ... both of them, and be ready to some really unexpected effects when e.g. knife cutting across them both.
However since at the moment we iterate over "unique data" most of the time, I think it is no surprise this doesn't work well.
Any thoughts gentlemen? cc @ideasman42 @fclem @brecht
My short-term proposal is to disable drawing of the non-object mode engines for dupli objects. And in the future we can have (2) implemented.
Also note that the bug is real and it only happens for meshes - curves, lattice, armatures, they are all good.
That said I stick to what I said, despite what we had in 2.79 I think we should NOT draw edit data for the the dupli data of the other objects.
Added subscriber: @Jeroen-Bakker
@Jeroen-Bakker looked into a bug related to this, but I can't find it quickly now. Apparently it was not trivial to make it work well with modifiers.
I don't care too much about drawing the edit mode cage for other linked duplicates, it is somewhat confusing. It has just worked like that for a very long time.
Added subscribers: @Sergey, @mano-wii
I investigated this bug and realized that the problem involves two areas.
The first is with the
BKE_view_layer_array_from_bases_in_edit_mode
call.It is behaving like
BKE_view_layer_array_from_bases_in_edit_mode_unique_data
since linked objects are not marked as being in edit mode.This can be solved by moving these lines:
The second problem is the
DEG_id_tag_update(vc.obedit->data, ID_RECALC_SELECT)
call inEDBM_select_pick
.It looks like some relation is missing because only one evaluated mesh is flagged as dirty in the
DRW_mesh_batch_cache_dirty_tag
.Ideally, each of the meshes of the linked objects should be flagged as dirty.
@Sergey, any idea why this is happening?
Selection update is tagging the input mesh via
BKE_object_data_select_update()
. There is only one such mesh.My speculation is that it is something in the object level which attempts to do early exit or something like this based on batch's
batch_ready
flags.Can not tell any more details, because i am not sure about specifics of how edit mode batches are shared and what is supposed to happen when.
Hey @fclem, is it team work time again? ;)
@Sergey From my observation, in the case of linked object data, Mesh* (ob->data) are shared in object mode but are not in edit mode. Which seems strange to me. When objects use modifiers it makes sense.
As @mano-wii notices It is indeed a problem of tagging as only one mesh is being tagged. Or maybe we could remove the need for another Mesh* in the first place.
@fclem, well, there is only one mesh to tag.. Anyway, design details which we can go into another time.
If my understanding is correct this patch should fix it, but i wouldn't mind if you give it an extra look/test: P1020: (An Untitled Masterwork)
I can confirm your patch works.
This issue was referenced by
26e6bb3fa3
