particle info (to-do) #65779
2 Participants
Reference: blender/blender#65779
Operating system:Linux Mint 18
Graphics card:GTX 750
Broken: (2.80,Hash:
2404220e80
, master, 2019-06-12, as found on the splash screen)Worked: (optional) Blender 2.79
Particle info node not working - This may not be a bug but something that has not been implemented yet.
Add an icosphere. Add a particle system to the default cube and in the Render settings set 'Render As' to object and select the icosphere. Then add a material to the icosphere. Open the Shader Editor and add a 'Math' node and a 'Particle Info' node to the material. Connect 'Age', from the Particle Info node to the first 'Value' input of the Math node and 'Lifetime' to the second. Set the Math node to Divide and connect 'Value' to the 'Base Color' node of the 'Principled Shader'. Switch to 'Look Dev' in the 3D view and play the animation, scaling the icosphere to see the particles clearly. All the particles are black, they should change from black to white as they fall. This is what happens in 2.79.
The attached file is a Blender 2.79 file ParticleInfo.blend. It runs correctly in 2.79, but opening and running it in 2.8 (from the 12 June 19) the particles do not change color.
Added subscriber: @craigievar
Added subscriber: @brecht
It's mentioned as a limitation in the manual:
https://docs.blender.org/manual/en/dev/render/eevee/materials/nodes_support.html
