2.79: Relationship Lines Not Visible for Stick/B-Bone/Envelope & Wire Bone Types
OS: Manjaro 18.0.3 Illyria
Kernel: x86_64 Linux 4.19.24-1-MANJARO
DE: KDE 5.55.0 / Plasma 5.15.1
CPU: Intel Core i5-2400S @ 4x 3.3GHz [61.0°C]
GPU: AMD TURKS (DRM 2.50.0 / 4.19.24-1-MANJARO, LLVM 7.0.1)
RAM: 2114MiB / 3920MiB
Broken: f4dc9f9d68b
Relationship Lines not visible for bone type other than Octahedral
3D View --> N panel --> Display --> checkmark Relationship Lines
Add an armature and parent one bone to another
Relationship Lines should be visible in Pose mode & Edit mode but is invisible for Stick/B-Bone/Envelope & Wire
I tried to replicate this using today's build (87de71a8aaa0) on a windows box but could not reproduce the described bug. I was able to see relationship lines for all armature display types in edit and pose mode. I do not have a linux box to test with.
I suggest you update to the latest version of blender 2.8 and re-test.
If the problem persists, try using factory settings with default scene to be sure you don't have a bug with an addon.
It's a version 2.79 build. 2.8 works fine, in factory settings the error is present. (2.79)
Not too sure if the devs are fixing non-crashing bugs in 2.79 any more.
However, firing up the default scene in 2.79 (same version as yours) and retesting showed exactly the same results for me in Windows 10/Nvidia GPU. All relationship lines show up in all armature display types. Maybe it's a bug specific to the Linux version or the AMD card.
Philipp Oeser (lichtwerk) renamed this task from Relationship Lines Not Visible for Stick/B-Bone/Envelope & Wire Bone Types to 2.79: Relationship Lines Not Visible for Stick/B-Bone/Envelope & Wire Bone Types.Jun 17 2019, 12:00 PM
Philipp Oeser (lichtwerk) closed this task as Archived.
Also cannot reproduce here in 2.79 (as well as 2.8).
And since this is confirmed to work in 2.8, I assume this can be closed [there are many things fixed in 2.8 which dont get a backport back to 2.79...]
