inversing the inputs entries in a node group generates a bug
Open, Needs Information from UserPublic
Graphics card: Intel(R) HD Graphics 630 Intel 4.5.0 - Build 26.20.100.6890
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-09 21:43, hash: rB030c7df19da9
[I noticed it a while ago moving a entry in the input of a node and not responding the same way after]
[I did a group node and then I tried a simplified part without any group, but when I put this part into my group I had a difference, even after having replaced every node by a fresh one and finally doing exactly the same simplified part into my group. I remember then this non responding saturation I had another time after having modified the order of my inputs. and then after having deleted every input and recreated them, without modify the order anymore. the problem were solved]
Related Objects
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
Not sure I understand correctly:
  • does this have to do with T64253?
  • mind sharing a blendfile demonstrating the problem?
  • not sure what is meant by "this non responding saturation", could you try to explain?
