Image pixel values change on reload of image
Operating system: Windows 10 Pro Version 1803
Graphics card: Nvidia GTX980
Graphics drivers: 430.86
Processor: Intel Core i5-6600K
RAM: 8GB @ 2400MHz
Broken: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-14 23:24, hash: 0fd96b4128ff, type: Release
Pixel values increase when a picture is loaded, saved, and reloaded using the Blender API.
Open a new blender file, create a new script and type:
import bpy
# path is the filepath of the image
path = "path/to/image.png"
loadedImage = bpy.data.images.load(path)
print(loadedImage.pixels[0:6])
loadedImage.save_render(path)
bpy.data.images.remove(loadedImage)
An example of the first print statement output in the console
(0.27450981736183167, 0.27450981736183167, 0.27450981736183167, 1.0, 0.27843138575553894, 0.27843138575553894)
Second print statement produces:
(0.30588236451148987, 0.30588236451148987, 0.30588236451148987, 1.0, 0.30980393290519714, 0.30980393290519714)
Related Objects
Jacques Lucke (JacquesLucke) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Jun 17 2019, 4:32 PM
I'm not able to reproduce the issue the issue.
Can you reproduce the issue with any image or just with this one?
I tested three random images I pulled from google, all of them have the same problem. The zip file contains the blend file I used (which has the script in it) and the original three images used, as well as what they turned out after running the script 10 times on them.
Any suggestions on how to proceed?
Jacques Lucke (JacquesLucke) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Jun 18 2019, 10:24 AM
Sebastian Parborg (zeddb) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.
@Brecht Van Lommel (brecht) Color management transform is saved. But I guess this is expected because the saving is done by save_render?
(Actually I think this has already been reported before, but I can't find the ticket ATM)
Use save instead of save_render, the result is not expected to be the same when applying view transforms, dithering, etc.
