X-mirror activated in Edit Mode missleadingly affects symmetry in Weight Paint Mode #65872
13 Participants
Reference: blender/blender#65872
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.80 (sub 74), branch: blender2.7, commit date: 2019-06-16 23:08, hash:
12da679fa0
When you activate "x-mirror" under "Options" in Editmode and switch to Weight Paint Mode, the x-mirror stays active for all weight paint actions even if symmetry is turned off in the Symmetry options (of the weight paint tool) which is very missleading... (took me half an hour to find out why there is a mirror on all my weightpaint strokes)
If x-mirroring is turned off in Edit Mode, everything works as expected.
Create a new blend file.
Subdivide the cube a couple of times.
Go to Edit Mode.
Check "X-Mirror" in the active tool settings.
Switch to Weight Paint Mode.
Switch to front view.
Add some weights with the brush to some of the verts in the cube.
Added subscriber: @pxp9k
#72064 was marked as duplicate of this issue
#71970 was marked as duplicate of this issue
#71804 was marked as duplicate of this issue
Added subscribers: @WilliamReynish, @ideasman42, @brecht, @lichtwerk
This is also the case in 2.79 and while could be improved [I see the point where this gets confusing], I think there are just two settings that have an effect on weightpaint being mirrored: the mesh option plus the paint option, if either one is active, mirroring will take place...
I would not consider this a bug at this point, but hesitate to close yet... Other opinions? @WilliamReynish, @ideasman42 , @brecht ?
I remember a similar discussion about X-Mirror being a tool option only [and the removal of the mesh option], but the outcome was in favor of keeping the mesh option...
Sounds like a bug to me, I don't know why both options should have an effect, especially if one of them is hidden.
Weight Paint mode is super weird. We actually have two mirroring options - Symmetry and X-mirror. I don’t understand why we even have X-mirror here at all
I guess this is related to the discussion in D3869 (also see https://blenderartists.org/t/x-mirror-behavior-in-2-8-poll-and-opinions/)
So there seems to be an advantage of having this per mesh not just as a tool option... (at least for mesh editing, I assume this goes hand in hand with weightpainting as well though...)
Looks like we could do two things:
I find it super confusing that we have both. It’s very unclear what happens if you enable one or the other, and it’s just generally confusing.
Symmetry is more powerful because we have X, Y and Z. I would just remove X-mirror from weight paint mode.
I agree.
Though I guess topological mirror may be useful? I guess it's possible to add that option in the symmetry panel, not sure how difficult it is to make it work.
Yes, true. That's the most tricky bit I suppose. Really we should ideally merge these things, so that you can do topological mirror for all axes, and have a single mirror setting, rather than the current two competing methods.
Agree it's in a very bad state.
The issue with this is currently these are different features.
.L
or.R
.Given this, we might be better doing the opposite and disabling symmetry mirroring until it's as capable as the existing weight paint mirror option.
@ideasman42
Ok, that makes sense - seems like it's better to add Y and Z to the X Mirror option and remove Symmetry.
Adding Y & Z will require many more changes, this wouldn't be for 2.80.
Added subscriber: @ChristophWerner
Added subscriber: @Semple
Added subscriber: @mano-wii
Removed subscriber: @Semple
Oops I confused the reports!
Added subscriber: @fauzan.rhrdn
This issue was referenced by
9569425b02
Added subscriber: @laurijh
Why were the symmetry options removed? I know there was a lot of confusion about the symmetry/mirroring options on the quick tool settings bar, but now the symmetry painting options are gone completely.
These were working fine and although I was not actively using them, I could imagine being able to paint with radial symmetry a useful feature in some cases.
There are several sources of confusion here.
Even though both are located in the same kind of Options menu, the edit mode Mirror options are not comparable with the weight paint mode X Mirror option. In edit mode the X Y and Z buttons behave just like the paint mode Symmetry options in that they echo any modifying actions across the given axes within the active selection.
On the other hand, the weight paint mode 'X Mirror' option has some unique features;
Some problems with the mirror/symmetry functionality and UI elements;
Button behavior inside Tool settings topbar changed sometime before 2.81 release for the better, but adding to the confusion when a 2.80 user upgrades to a newer build;
The word 'Mirror' is used with all of these options in every mode
Decoupling the unrelated options and clarifying the UI terminology would help a lot.
Added subscriber: @PabloDobarro
Reading the discussion, this seems like a missing feature with a confusing UI that requires further design and implementation, so tagging it as a know issue.
Added subscribers: @crantisz, @iss, @JacquesLucke, @Maker26, @angavrilov
Added subscriber: @darklord666
I want to chime in here. My mesh is currently asymmetrical (working with clothes), and right now I am not able to use X Mirror or X Mirror Topology properly, to automatically apply the same paint strokes to the opposite bone. My bones are named correctly (.l and .r), origin is correct, etc.
I understand that if the topology is not an exact mirror then it's more difficult, but when I use Symmetry X Y Z, the brush is able to match the paint job pretty damn well from one side to another. So I can see it's technically possible, but no matter which one I choose, it won't paint to the other bone properly.
I've seen some people say that if the topology is not exactly the same, then it can't work. But using Symmetry X Y Z shows me that it can and should work. I've checked that my origin is correct, rotation location and scale are applied.
Right now my own workaround is:
This works decently. But is annoying. If anyone can direct me that'd be great.
Added subscriber: @rwman
Added subscriber: @Mets
I would say this has been resolved by a combination of various patches over the last year, starting with blender/blender-staging@5502517c3c and ending with
fa9b05149c
