make update_po failed #66066
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#66066
After performed:
svn update .
at the 'blender_docs' directory, to bringing latest changes in the documentation, if you then run
export LC_ALL=C.UTF-8; export LANG=C.UTF-8; make update_po
you will get this error:
svn: warning: W150002: '/home/htran/blender_documentations/blender_docs/locale/vi' is already under version control
svn: E200009: Could not add all targets because some targets are already versioned
svn: E200009: Illegal target for the requested operation
Makefile:165: recipe for target 'update_po' failed
make: [update_po] Error 1 (ignored)
and it's down to the line above mentioned line of code 'svn add $NEW_DIRS' in the following section of code:
NEW_DIRS=
svn status . | grep -v -e "\.po$" | awk '/^- [x]/{print $2}' | python -c "import sys, os; sys.stdout.write('\n'.join([f for f in sys.stdin.read().split('\n') if os.path.isdir(f)]))"
if [ "$NEW_DIRS" != "" ]; then
Multiple args, don't quote.
svn add $NEW_DIRSfi
unset NEW_DIRS
from the file
blender_docs/tools_maintenance/update_po.sh
Printing a few debug lines out and it comes down to the
'locale/'
that was found, but this directory is already under 'svn' control for translation and it has NOTHING to do with manual repository. The following line fixed the problem:
if [ "$NEW_DIRS" != "" && "$NEW_DIRS" != "$LANG" ]; then
Added subscriber: @hoanguk
Note that this is working for me, most likely a difference in my svn checkout which holds all languages. in
locale/
Added subscriber: @Blendify
I also have all the languages and works for me.
Would that then be the location of '.svn' directory? I have this under 'locale/vi'. Yours are probably in 'locale'??? I've followed the instruction in the manual
https://docs.blender.org/manual/en/dev/about/contribute/translations/contribute.html
and clone the svn of translation as:
svn checkout https://svn.blender.org/svnroot/bf-manual-translations/trunk/blender_docs/locale/vi locale/vi
As a language translator, I don't think the existence of other languages are necessary, and thus did not download the whole set of languages to my local HDD.
Right, this is a problem with the script that needs to be fixed.
This issue was referenced by 5204
Thank you Campbell.
Sorry to have raised this again, tested tonight and it doesn't work, failed on the line:
svn add $NEW_FILES
Added for loop to perform 'svn add' on single instance of new files appeared to work:
Please correct this. Thank you.
By the way, I won't update the locale/vi repository so you can download to your local HDD to test, using:
cd blender_docs
rm -fr locale
svn checkout https://svn.blender.org/svnroot/bf-manual-translations/trunk/blender_docs/locale/vi locale/vi > /dev/null
Changed status from 'Resolved' to: 'Open'
Could you try again, this should be fixed rBM5298.
OK, I'm waiting for some more changes on the repository to test later. I had a gut that it's down to command line buffer's limit. Look at the cut off of the last-line in the screenshot of the error.
Ran test to 'make update_po' today and it appeared working. Closing this log as resolved for the moment.
