Extruded text with transparent BSDF node loses viewed face in Eevee
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.35
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-06-24 18:46, hash: rBc0c1b4542f39
Extruded text with transparent BSDF node loses viewed face in Rendered and Lookdev under Eevee but shows opposite face through the inside of the text.
Add text object – default font will manifest problem
Extrude text using Text tab > Geometry > Extrude
In Shader Editor, Use Nodes
Add Mix Shader between default Principled BSDF node and Material Output node
Add Transparent BSDF node and link to empty shader input on Mix Shader node
View the text in Rendered or Look Dev viewport shading.
Looking into this, it would appear this may not be a bug.
To get a transparent result the blend mode is set to alpha blend. When combined with show backfaces, the end result makes the backfaces appear more prominent.
