Subdivision Modifier Glitch #66288
Reference: blender/blender#66288
Operating system: MacOS 10.14.5
Graphics card: RX Vega 56
Broken: Version 2.80 (2019-06-26)
ERROR
One edge is sharp despite the proper geometry used in tandem with a Subdivision modifier. I've tried deleting and recreating the edge which will give random results depending on the order of steps usually. However, this is not consistent. Merging vertices based on distance does not fix anything either.
Based on the default startup or an attached .blend file (as simple as possible). I don't know how to recreate exactly. I've attached the file and made a Vertex group named "ERROR EDGE" which will select the trouble edge.
Vector.blend
Added subscriber: @rawr-1
Added subscriber: @MarcinTwarowski
Part of your mesh is inside out. You can see it if you check "Face Orientation".
That's why I usually work with "Backface Culling" on.
Select all faces and recalculate normals. However, newly created faces shouldn't point in other direction, so maybe there is a bug somewhere.
Added subscriber: @brecht
No bug here as far as I can tell, there are many cases where inconsistent face orientations can happen.
That's embarrassing. Thank you Marcin and Brecht. I learned something new!
