This was fully replaced by the workboard of Render & Cycles .
Related Objects
Related Objects
Status | Subtype | Assigned | Task | ||
Confirmed | DESIGN | None | T63725 Module Owners Todo's (parent task) | ||
Archived | DESIGN | None | T66305 Render & Cycles Module |
- Mentioned In
- D3509: Add support for tiled images and the UDIM naming scheme
T71253: Cycles shadow catcher improvements
T37814: Artifacts in Cycles render for lowpoly models.
T63725: Module Owners Todo's (parent task) - Mentioned Here
- T77533: Switch Cycles task scheduler to use TBB
T76259: Cycles OpenImageDenoise improvements
T74581: Cycles: adaptive sampling improvements
T73778: Cycles: Embree improvements
D6250: Fix T43835, T54284: Cycles with no ray offsetting
D6554: Cycles: Add support for denoising in the viewport
T63064: Cycles viewport render border no longer shows scene behind with OpenGL
T73266: Improve custom shader AOVs
T72390: Improve UDIM functionality
T72337: Shader Node Additions
T52725: Branched path unification
T72293: Refactor AOV writing in Cycles kernel
D2149: Cycles: Add optional Blue-Noise Dithered Sobol Sampling
T69800: Cycles Optix feature completeness
T69801: Cycles Optix tasks for 2.81
T53901: Cycles adaptive subdivision tasks
T68823: GSoC 2019 - Cycles/EEVEE Improvements
T68914: Cycles adaptive subdivision
T68915: Light linking
T68916: Many light sampling
T68917: Cycles: texture cache and mipmaps
T68918: Blue noise dithering
T68919: Scrambling distance
T68920: Cycles: improve shadow terminator handling
T68921: EEVEE baking
T68922: Displacement baking with Cycles
T68923: Vertex color baking with Cycles
T68924: OpenEXR pipeline improvements
T68925: Baking workflow revamp
T68926: Color Management Improvements
D5363: Add OptiX device implementation to Cycles
D2808: Cycles Networking support
D3607: Cycles: Implement render passes that contain all lighting from lights in a specified group
D4204: Ray and Shader counters for Cycles
D3202: Cycles/UI: Implement dropdown menu that shows the available attributes in the Attribute node
D4837: Cycles: Add support for adding custom AOV render passes
D3959: Compositor: Redesign Cryptomatte node for better usability
D4255: Cycles: Added feature overrides
D4676: Cycles: Improved sampling for sphere lights.
D3203: Baking system overhaul: Move baking settings from render settings into BakePasses
D4304: Compositor: Added denoising node
D4459: Cycles: Added fix for bump terminator problem.
D4686: Adaptive Sampling for Cycles.
There are a very large number of changes, so older changes are hidden. Show Older Changes
This comment was removed by Maciej Jutrzenka (Kramon).
This comment was removed by Brecht Van Lommel (brecht).
Julien Leménicier (mistajuliax) added a subscriber: Julien Leménicier (mistajuliax).Nov 4 2019, 9:44 PM
Brecht Van Lommel (brecht) removed Brecht Van Lommel (brecht) as the assignee of this task.Jan 18 2020, 2:25 PM
