Empty with Vertex Parent moves to origin when mask modifier hides parent vertex #66440
Reference: blender/blender#66440
Graphics card: GeForce MX130/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.25
Broken: version: 2.80 (sub 74), branch: master, commit date: 2019-07-03 22:34, hash:
c252fe7a32
If you have an empty parented to a vertex of a mesh, and you apply a mask modifier to the mesh which hides the parent vertex, the empty moves to the mesh object's origin. This behavior is inconsistent with what happens when you hide the parent vertex in edit mode using the h-shortcut. In that case, the empty remains in position relative to the hidden vertex.
I prefer for the empty to retain its position if its parent vertex is hidden by the mask modifier. If this behavior is intentional, or a known limitation of the mask modifier, I haven't been able to find it. Apologies if so.
Hmm. Actually, it seems to move even when I exclude the parent vertex from the mask. ? This is highly confusing. Are mask modifiers incompatible with vertex parenting altogether?
Parent an empty which is not at the world origin to a mesh vertex.
Assign the mesh parent vertex to a vertex group to be used in a mask modifier
Add a mask modifier to the mesh that hides the vertex group
Note that when the modifier is active, the empty has moved to the mesh object's origin
Note that when the modifier is not active, the empty is back in position.
mask_vertex_parent_movement.blend
Open file.
Note position of empty sphere.
Turn on mask modifier view port visibility
Note changed position of empty.
***Updated to fix some mistakes in bug report
Added subscriber: @CraigD
mask_vertex_parent_movement2.blend
So this also seems to apply when the child object is a mesh. I've added to the file to demonstrate this. In this version, the child cube is parented to a vertex in the larger cube. The empty is also parented to a different vertex in the larger cube. The empty's parent vertex is excluded from the mask. The child cube's parent vertex is included in the mask.
In both cases the child objects move to the parent cube's origin when the mask modifier is active.
What's strange is that in my character model blend file, there are some parented empties that do not move when their parent vertex is excluded from the mask, but others that do move once the mask is active regardless of mask vertex group membership.
Added subscriber: @ZedDB
This is not a bug as this is how the mask modifier works. It removes the masked faces/verts. So the vertex you have parented the object to, no longer exists when the mask is active
Alright. I'll leave it alone.
But the point of the second file was that the child object moves even when the parent vertex is not itself masked. So the parent vertex is still present and visible. But maybe the modifier is creating a whole separate mesh to replace the original or something.
Thanks for taking the time to respond.
Added subscriber: @lichtwerk
Heads up: this should now work, see
5168408ae5
